How do I remove my alternator - please help!
I'm hoping it will be this and not alternator, looks like someone has already tried to remove before and that Allan key head looks fairly rounded already!
I have the top two bolts off already, are there any others??
1990 - Cabriolet GTI 1.8 (DX)
Chairman
However getting the new alternator back in was a pain for me, as the one I got was a recon (from GSF, they offer a trade in for your old one)and they painted it, with some mighty thick paint! Wouldn't go back into it's nice spot on the engine block
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Have a question though, I have a little 2 prong metal bit (attached to alternator) that I think needs to touch something on the regulator… but mine doesn't. Hoping the pics can show what I mean - any advice?
Will look to replace the alternator but it will have to go to a garage as someone has tried previously and the head is rounded into a perfect circle !
If you have a picture that would help.
thanks
There is not much room to work so it may be easier to remove the bracket and the alternator as that has 3 bolts holding it on the engine but you will need to remove other stuff to get to the bracket.
If all else fails some big mole grips on the end of the Allen key bolt.
New bolts can be bought of eBay or a good nut and bolt shop. Smear the new bolt in copper grease so it does not seaze and you have the same problem a few years down the line.
Picture of bracket removed and you can workout the 3 bolts holding it on, 2 on the side and 1 at the front. The 2 on the side also hold the engine mount and 1 hold the cambelt cover.
Picture of bracket and bolt,
Last edit: by mark1gls
Will try what you suggest.
Much Appreciated.
I have the same problem with the engine I took out to swop with in the picture, I found there is not a lot room but I was lucky as I did not need to remove my alternator but I had to tap it with a hammer to move it when changing over the alternator belt.
I know it is only plastic, but don't really want to break it.
if you mean the lower one you just need to remove the crank pulley to get it off, plus possibly the waterpump pulley. you might be able to get enough wiggle room with just the crank pulley removed so you gain access to the bolts holding the lower cover on to get at the alt brackets?
its been so many years since I did this job I cant recall exactly how i did it
Chairman
Here's a diagram of the way it fits, if I were you and you have a welder about. Get some threaded bar, put 2 x nuts on the one end and weld in place, then spot weld the other end of the threaded bar to the end of the alum key head and get it out like that, you'll probably have to hack saw it off when you can access the head as they're tight against the chassis leg anyways, but it might save you a lot of timing hassle!
Follow us on:
Follow us on:
