Loud squeal and juddering.
1990 - Cabriolet GTI 1.8 (DX)
mark1gls said
No worries,
let us know how you get on with the belt.
Helloooooo : )
Belt was replaced yesterday and that silly noise has gone (thankfully) Have a new one now though - I (think?) this one is due to belt being new though. It kinda sounds like a super charger does when you depress the accelerator more and more, a whirling noise, make any sense to anyone??
Has anyone touched your cam belt?
The other reason why the car sounds like its supercharged is the cam belt is to tight.
mark1gls said
It could be the belt is to tight, if you press the belt halfway between the alternator and crack shaft it should move about 10mm with using just your index finger.
Will have a look tomorrow, no-one has touched the cam belt (or at least I hope not) The noise has only kicked in since the alternator belt change??
Is this normal?
And will something happen if I keeping throttling whilr this happens?
After about a week you will need to check and possibly re tighten it as they stretch.
Some are either too wide or narrow and don't sit in the pulley grooves properly.
