MK1 Golf GTI 2.0 TFSI Edition 30 p12 (was 2008cc R1 bike carbs)
1983 Lhasa Green MK1 Golf GTI
I wonder what tailgate badge I should use this week?
Bet there's not many of those touch up paints in existence mate
It's still full of fresh paint too, and still smells new.Melteddrummer said
I opened it and touched up a few bits at the weekend. cf_emoticons__BangHead:
Melteddrummer said
That catch tank looks nicely made!!
I wish I could weld like that.
I think it only cost £35-40 quid too. Bargain really.
Like the touch up kit too!
Hairyarse said
That a nice catch tank, like the welding
I only wish I could say it's my handy work! (although I did fit it )
I also had a newer touch up kit, but that had dried up.
found me a set of R1 carbs so its just a case of the manifold now…
Instagram Firemandan1
dano999 said
Great thread, Im thinking its a bit more involved fitting the bike carbs then i thought.. im not that lucky for it to be take off, bolt on , job done haha….
Would be great to see another 8v R1
It's definitely not far from being a just a spanner job. I forgot to mention in the thread you also need use a bike brake cable to operate the accelerator pedal, but this again is easy to sort out.
So I could fit these, polycarbonate glass all round (except the windscreen)
While fitting the fronts ,new clips were used, a new coat of paint for the bracket and new rubber trim.
This was the first time the windows had been removed since leaving the VW factory in 1983. Amazing to see how clean the body work was underneath the window seals, meaning the new windows could be put straight in.
Back window - again never been removed from the car before, a bit fiddly to remove, and a bit fiddly to ensure the new glass and seal refitted perfectly. But got there after two-three attempts.
Back seats removed. Weight saved: approx 8kg
No spare wheel. Weight saved: approx 12kg
K-Jet metering head and braided lines removed. Weight saved: approx 10kg
Carbon fibre bonnet. Weight saved: 7.68kg
Polycabonate glass. Weight saved: 9.56kg
Lightened flywheel. Weight saved: 1.74kg
Weight saving to date: 48.98kg The weight saving on a pukka stripped out MK1 Golf track car with no bumpers, light weight doors and seats must be huge!
Set of new NGK B8ECS plugs to replace the current Bosch Super4's WR78's. The Super 4's have been on the car for the last four years, so were overdue for replacement.
The B8ECS plugs had been recommended for a high spec 8v engine. The B8ECS is a colder plug than the B7ECS, which I believe is the standard replacement spec plug?
I'd found this on the web, document listing the B8ECS plugs 'for race engines'. Oooh! http://www.rallyboutique.com/produkter/golf/Prislista%20Golf%20MK2.pdf
Anyway.. spanners outs, few minutes later, new plugs fitted.
http://www.youtube.com/watch?feature=player_detailpage&v=GMVoacI48ZY
3rd/4th gear mid range torque. I think my porky Sebring wheels stunt the acceleration a bit, but the engine has still got that 8v torquey characteristic
http://www.youtube.com/watch?v=k3OsjcpD1P0&feature=player_detailpage
Edit: Just found the comcode tag assistant so have now embedded the youtube link. Thks Hopefully be able to post a few more pics shortly of the last bits of bodywork to do, as this didn't happen over Winter.
Last edit: by Lhasa2008
Complete rear axle from Polo GTI 6n2 including callipers, carriers, disks/pads, brakelines, stub axles and abs sensors all for £64.00
Callipers and carriers removed.
Disks/pads and rear bearing/hub removed. (All original parts - still had OE VW sticker on them!)
Stub Axle removed
Complete axle now stripped down, ready for a clean up.
Next job will be to check the callipers/carriers and get rid of the red paint, as I would prefer a more MK1 OEM colour, either a zinc gold/silver or maybe black?
matt
pazwaa said
a nice looking pile of parts, will look great once refurbished
matt
I hope so, I'll be digging out the dremel this weekend.
GSF and Eurocarparts are charging ridiculous amount for these particular calipers, so hopefully a little bit of cleaning, tlc and a lick of high temp paint should save me a heap of money.
Matt
The Polo 6N2 GTI stub axles have now been removed and cleaned up. And took delivery this week of some Scirocco 16v handbrake cables and conversion cables.
Lhasa2008 said
pazwaa said
Cool, hopefully be over to the vw festival Sunday morning, so will come find you. Hope weather is better than last year
rain, arrgghhhhh!!! (fingers crossed then!)
Just re-read your thread and saw this. A year late, but I got to chat to you eventually
Thanks for talking me through the finer points of bike carbs on Saturday, hopefully put it in to practice soon.
Matt
