MK1 Golf GTI 2.0 TFSI Edition 30 p12 (was 2008cc R1 bike carbs)
1983 Lhasa Green MK1 Golf GTI
top tip #2 - Make sure you have a supply of replacement steering rack boots.. cf_emoticons__BangHead:
Top tip #2 - Don't just do a 'quick repair' and put back on the car..
New hot-tuning stainless steel four branch manifold
What's better than spending an afternoon in your garden..wrapping a new manifold.
Manifold refitted. Note that the hot-tuning one has alot more clearance against the steering rack boot than the Supersprint one. :-)
Comparision, Hot-tuning left, Supersprint on the right.
Hot-tuning (right) slight larger exit diameter.
Comparision Supersprint (left), Hot-tuning (right) welded up to Supersprint Grp.A middle section.
Little bit of fiddling to make sure middle section clears body work and rear axle.
Last edit: by Lhasa2008
Original engine, standard k-jetronic fuel injection with TSR 2008cc bottom end. standard spec cylinder head. April 1998
Hairyarse said
Nice old pics!
Thanks. Was taken with when cameras had 'film'!!
Cero said
Those Corrado wheels look the business and so easy to keep clean
Definitely easier to clean than set of three piece BBS's!
Sebrings have a rather understated OEM look about them. A 'marmite' wheel - you'll either love them or hate them!
Thanks mate.smudger said
Love the old pics mate. She's a lovely car.
Your's ain't bad either I've been tinkering with my spanners in the garage today..I may have just spoilt it..
As you can see the car has kept most of the original features Obvious change is the 15" Sebring's instead of the original 13" alloys. It would be great if they did them in 15's.
It's still has an 8v engine, but this has slowly been modified over the time I have owned the car.
First upgrade was a TSR 2.0 bottom end to replace the tired 1.8. Keeping the car as an 8v, the bottom end now had a 2.0 crank and 83mm pistons, making 2008cc.
Having connected this up to the original 8v cylinder head and standard GTI camshaft, I now had lots of low down torque and very little increase in bhp!
Power 114 bhp
Torque 133 lb/ft. (at something like 2000 rpm)
To help keep to oil temperature down, the original oil cooler was replace with a Mocal 13 row item. Since fitting this the engine has never exceed 100 Deg.C (even on a track day!)
An instand 10 bhp bolt on upgrade!
Power was now 124bhp.
Torque 151 lb.ft.
A Kent GS2 camshaft was also fitted at the same time.
Fifth injector installed as part of K-Star mapped fuelling, still using original K-Jetronic injection system.
K-Star ECU piggy backed to original ECU:
Power was now 129.9bhp
Torque 129.8 lb.ft.
With 31bhp loss wheels .
Figures recorded at Stealth Racing.
So new shiny cylinder head sat there while the bodywork, fuellines and brakes, suspension were sorted. This took a looong time!
Although I got to know the parts dept at the local VW dealers very well, as I had a new shopping list every other week!
Melteddrummer said
That a nice mk1 mate, I love the sebrings. You certainly like a bit of tinkering lol, I wish I had more knowledge engine wise, just to be able to tweak things the way you have.
Thanks.
With the amount of welding and body repair skills you now have, spanner tinkering will be a doddle! IMO, it's easier than crawling under a car welding in new panels!
Cero said
No wonder it runs so cool, I think you must hold a gallon of oil in those oil cooler pipes alone
Ha!
That's why a buy the oil in 5 litre bottles
I then drove back down to Stealth Racing for the K-Star to be remapped. Here is the result:
Power 146 bhp @ 5953
Torque 148.1 lb.ft.
Power loss 30.4 bhp
That was more like it!
Cero said
With figures like that it'll be a nice torquey engine to drive I bet
It drives much better since the big valve head was fitted. Before that, all the torque kicked in at low revs, making slow progress in the wet.
The power is much more progressive now. I can only imagine what a TDI engine in a MK1 will be like
