Best gearbox for 1.8t conversion
(In Topic #148794)
The box has the side bolt through mounting holes for the mount
JonP said
g60 or a diesel box
Apologies hijacking this thread, Is there a suitable mk4 diesel gearbox that could be used?
If so, which gearbox code would folk recommend?
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
collo16v said
02J with 100mm cups is a proven choice
Anyone know how much power/torque can these handle?
No idea but i had both 02J and 02A, looked at the gearing and the 02J will hit almost 70 in second unlike the 02A just about 60 at 7k rpm but the the 02J was almost flat out at 135 mph and the G60 box was 168 mph at 7k in 5th.
G60 box is the way togo if you want lower rpm to speed..
02J with 100mm cups are only from the very early 20v mk4 golfs, not sure on other models if any…
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
I can only imagine what 168mph feels like in a mk1.. 8O
Useful info on the mk4 box, thanks. Lhasa2008
higher1 said
After looking into it the ENJ or EHA have the highest petrol ratio boxes of the o2j range il be fitting a ENJ in the new year
Hi, it would be good to see how you get on with the ENJ.
Lhasa2008
Lhasa2008
I will update the post once it's fitted will be a while yet as the car is stripped ready for painting in January
Birmingham
c11rgd said
hi mate did you want my ENJ box??
Hi I bought one local to me in the end
the later mk4 boxes have an improved shifter setup over the 02j and early mk4 02j you can convert an older box by sweappign the shifter tower as well as the gear shifter box and cables. if the mk4 cables are too long polo and seat have shorter ones which may help but again you need the right shifter and cable setup to match the tower on the box
1983 VW Golf GTi
2014 VW Transporter 2.0 TDi Daily
I can confirm that in the wet at 6000 rpm it is very exiting! For some reason the speedo has decided to not work since the dash and gearbox swap.
I was hoping to put the newer shifter/selector in as well yesterday but have some parts missing, can anyone point me in the right direction please?
The Audi short shifter is on my list to buy but the ones I'm looking at online are just the big cast metal piece with the pins to go in the ends of the newer shifter but it looks like I need a bracket of some sort?
Last edit: by Pete M
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
the tower you mention is the right one, but ask audi sometimes they are cheaper than ebay
there are 2 types of 'late' 02j tower as well, early-late and late-late. early-late have ball end cables, late-late its pin end like what you have,. if its an early-late you have you can still use it, either put the early end on your cables or swap the linkage piece the cable attaches to match your late-late ends. the cables and gearstick are the same either way
Do I need all of this, that looking like expensive!!!
shift rod, shift rail, selector fork, for 5 speed manual transmiss. | EBF,EGS,EBD,, EGV,EBM,EGW,, EBN,FBX,EGY,, ENJ,EVS,EBJ,, EGR,EWU,EHA,, EUH,EVQ,EXE | |||||
1 | 02J301231A | selector housing | 1 | EBF,EBJ,EBD,, EBM,EBN,ENJ,, FBX,EWU | ||
1 | 02J301231B | selector housing | 1 | EGS,EGV,EHA,, EGR,EGW,EGY,, EVS,EUH,EXE,, EVQ | ||
1 | 02J301231B | selector housing | 1 | |||
2 | 02A301227M | shaft oil seal | 24,3X6,4 | 1 | ||
2 | 02A301227C | shaft oil seal | 24,3X6,5 | 1 | ||
3 | 02K945415K | switch for reversing light | 1 | |||
4 | 02J301127 | lock screw | M8 | 1 | ||
5 | 02A311648C | ball sleeve | 15,2X23X23 | 1 | ||
6 | 014301485 | cap for venting the gearbox | 1 | |||
7 | 02A301320B | stop ring | 15,8X28X1 | 1 | ||
8 | 02J301233F | shift rod | 1 | EBF,EBJ,EBD,, EBM,EBN,ENJ,, FBX,EWU | ||
(8) | 02J301233R | shift rod, G >> 05 08 1 | ;1 | EGV,EGS,EGR,, EGW,EGY,EVS,, EHA,EUH,EXE,, EVQ | ||
8 | 02J301233AC | shift rod, G >> 06 01 3 | ;1 | EGV,EGS,EGR,, EGW,EGY,EVS,, EHA,EUH,EXE,, EVQ | ||
(8) | 02J301233AF | shift rod | 1 | EGV,EGS,EGR,, EGW,EGY,EVS,, EHA,EUH,EXE,, EVQ | ||
(8) | 02R301230D | switch unit, also use:, — MQ250 - 5 GANG—— | 0A4 301 256 C | 1 | EGV,EGS,EGR,, EGW,EGY,EVS,, EHA,EUH,EXE,, EVQ |
yes to convert early 02j to later 02j you need part 1-8 off a donor car in scrappy. plenty of mk4 in there to rob oen from its not specific to the 20v most of the 4 cylinder mk4 use a variant of the 02a/j. just ignore the really poverty spec with 020 type box or luxury spec with 02m 6 speed
the tt shifter ou need is for 5 speed 2wd models only, part number 8N0711051, 8N0711046 or 8N0711051A. this type:
https://www.ebay.co.uk/itm/172144221592
as I say check with audi though, they only want 32.77 for the lever
