Mars Red 1.6 GTi Converted Driver..........
Flew through it's MOT yesterday, only close shave was having to switch back to the old GTi wheels which have old perished tyres with a few cracks in them which got me a couple of advisories.
Engine still isn't running anywhere near like it should but now I can get it to people to maybe have a look.
Jobs done since buying it;
New starter motor
New discs and pads
New rear shoes and springs
New rear wheel cylinders
New off-side caliper
New brake bias controller
New hazard light switch
Multiple new sections of brake pipe made and added
1 new sidelight bulb holder.
Terminals cleaned on indicator plugs and relay and a random broken purple wire under the dash re-connected
Various bulbs replaced
Horn replaced with one from an E30 to get it working
New wipers
All filters changed
Oil changed
Various vacuum pipes replaced or tidied
Throttle body cleaned out and refitted with liquid gasket
Rear arches and floor painted in POR15 chassis paint
Sills round back and resprayed
Metering head massaged and checked by Jellybelly
Still much much more to do but at least it's on the road.
Car has been SORN'd since the end of OCT but going to drag it out with a view to getting along to UD next month.
Last summer was good fun but highlighted a few issues, rear shocks are goosed and I really want some more ooomph. I've got some shocks ready to fit but will also get some new bushes while I'm at it. I also want to sort the ride height, I'm happy with how the rear sits at the moment but dare say it'll raise a little with new shocks. Does the front look like its standard height? I'm thinking to 40mm springs should suffice.
Took it down to the German show last summer at Beaulieu motor museum in the New Forest and it didn't miss a beat. Few pics from that weekend;
I'm guessing the front is standard ride height - it looks about right for that
Cool, thought as much. Think I'll try some 40mm lowering springs then.
olethalb said
what wheels are they and whats the width?
They're made by OZ, most common name I've seen used is Turbine. The original finish is more of a chrome look. They're 15x7 but have quite a high off set causing the front to poke a bit, I'd prefer they didn't but there's not really enough meat on the backs to have machined off and pull them in.
I've got a set of nearly new weitec shocks and springs that lower by 40mm on ebay if you decide to go that route
Matt
Got them fitted today, all went to plan which is always an bonus and never actually expected! The kits came with very good top mounts but my car actually has poly bushes so used my rear mounts but kept the fronts as they were as I hadn't got my spring clamps at home.
Old vs new;
Happy with the amount it looks to have dropped, just thrown the the GTi wheels back on for now as I've still got to torque everything back up (yup, torque wrench isn't at home either). Hoping there's not going to be any clearance issues on the rear, pic of a quick trial kit of one of the OZs, looks better already and hopefully it'll settle down a bit more to;
'83 formel e
Oz looks good too
jellybelly said
Looking good Dave
I may need you and car soon to try something in it I shall let u know
That sounds dodgy!
looking forward to full car pics with OZ's on
Nice being back in it after a few months away. Ran it down to my mums loaded up with the OZs in the boot to give them a good clean and wax before refitting. With them in the booth and a big jack there was no sign of any rubbing.
Then with the wheels swapped and loaded back up the rubbing was back when going over bumps so looks like it is all down to the size/offset of the OZ
Took it for a good run this morning as well and at decent speed on bumpy roads there was the odd rub with just a spare in the boot Looks like I'm going to be need somekind of arch work…………..
