'79 diesel LHD
'79 diesel LHD
Well I had a play with the bead blaster and then some spray cans, and spent a bit of time masking:
I'm quite pleased. If the weather stays nice I'll do the other three tomorrow and get some tyres fitted.
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
Chairman
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
36thCrazyFist said
Nice job on the masking mate, more patient than me!
It does take a lot of patience - I'd planned to do the other three today but various jobs got in the way, and I only managed one…
As started - I'd tried hand-painting the insets in an earlier attempt, but my hand was too shaky!
First bit of masking is easy:
Next bit takes a little longer:
All the little edges done and ready to paint:
Three coats and an hour to dry:
The bit I like best:
The final shot - not perfect but good enough for me:
It takes about an hour per wheel - 45 mins to mask and 10 mins to paint (5 mins left to open beer and admire)
Robin
the wheels got fitted to the cabriolet in the end, and the tracking done at the same time, but that's another story…
Robin
following a few issues with difficult starting I've done a little maintenance today. First, a nice big battery will help, and with Golf Mk3 battery cables adjusted (dremel) to fit there's no question of voltage loss now. The new one is a 70ah compared to a 55 ah previously.
The battery leads were longer, and fitted easily enough, though I've left the original earth strap across the gearbox mount for the moment. The new negative lead goes to the body under the battery and then to the top starter motor bolt.
On the other side of the bay, there's a 65A alternator in the place of the 45A original, and now I'm getting 13.5V on tickover, so let's hope it holds out.
I also changed the diesel filter at the same time (2 years and 28k kilometres on the old one) and, as before, was amazed at how easily the Bosch pump self-primes. I simply unscrewed the old filter and screwed on the new one, without even filling it with diesel, started the engine and it ran for nearly two minutes on fumes, with the revs slowly dropping, until the filter filled and the diesel began to flow through the transparent pipe. At that point the revs rose slightly, end of job!
More welding soon, I think…
Robin
Hairyarse said
That new battery should do the job
It does, instantly. She's never started so well, and I've never heard the starter motor spin so fast - like a turbine!
Robin
jellybelly said
The main thing with diesel is cranking speed so you've done nice work improving that
A while back I rebuilt my starter all new bushes and it made a huge difference
You beat me to it. Watch this space, I've just finished repainting a Golf II TD starter body and fitting new brushes, to replace the turbo starter if needed.
Robin
Robin
Start of play this morning:
Three hours later (there's a lot to remove on a diesel):
There appears to be no damage to the block:
The head looks OK after a quick clean:
It has got small cracks between valves in cylindres 2 and 3, but this is apparently not a problem. The water-pump housing was hard work, with two sheared bolts, but I managed to extract the remains by welding nuts onto the stubs.
Now it's a question of checking everything, changing what needs to be changed, and careful reassembly.
Robin
The head is still fairly oily, and the light out in my stable isn't good. What did you see?
Robin
Robin
Then after welded a skimmed
yours isn't as bad but that mark could be the issue
Last edit: by jellybelly
