'79 diesel LHD
'79 diesel LHD
A NOS Hirschmann, still in its box:
Kind of easy to fit - no plastic inner arches and under the dash is only carpet, but it's a bit tall!
Then remove the plastic cover:
Clean up the holes:
Fit the mirror:
Clean the car a bit, but no need to polish in Winter!
And put her away to dry:
Here's the radio - no plate yet but I'm working on it. I can pick up 7 stations now, three in English, two in French and two in Dutch:
Next job, figure out why the reversing lights and the clock don't work.
Come to think of it, the reversing lights don't work in the cabriolet either.
Robin
VW Golf 1500D 5-door 1978 - was daily (wet)
VW Golf 1800 cabriolet 1980 - daily (dry)
Bedford CF Trailblazer 1978 - camper
Bedford CF 350 Flatbed 1976 - fun/work
Mercedes W108 280s 1970 - dusty and forgotten
Mercedes S123 200T 1983 - to be renovated
Mercedes C124 1989 - Winter Beater
BMW E21 1976/82 - dusty but not forgotten
Twingo 2004 (not my fault, somebody gave it to me!)
Early-1800 said
When I had a 1.6D Caddy it would average 55+mpg on a bit of a run (5spd gearbox). A previous Jetta 1.6D (4spd G/B ) used almost entirely on short runs would do @40-45mpg. So your average sounds about right and about right for a Diesel, you sound surprized? Are you used to filling up a V8 petrol?
Not so surprised, but it is reassuring. My 1800 cab does 35+mpg on petrol, but diesel is a lot cheaper over here, so using the diesel halves running costs. Petrol is 1.55 euros (£1.25) a litre and diesel is 1.35 euros (£1.10) a litre.
Robin
Now it's holiday time, so I'd better get on with the car. Plans are a little welding, a driveshaft boot, a steering rack gaitor and the later front brake upgrade. The small brakes are actually not that bad - I think a large part of the problem must be in the RHD setup…
Here's the first problem:
Hoping it's not too bad:
Clean it up:
Cut it out:
Weld in a new piece:
Clean up and reweld the bits you missed:
Tomorrow I'll do the second skin, but I'll have to improve my technique. It comesof not having touched the welder in the last ten years,rusty wire, a dodgy torch and shaky hands…
Robin
here's the outer arch after another hour's work:
Sorry, no before and during photos - the batteries were charging. The welder runs better on clean wire, and my technique is less pigeon poo, but I still blow a few holes here and there. Metalwork should really be left to the pros, as you can see every hammer blow in this piece. On the other hand, it will be covered by the spat, and with a quick skim of filler no-one will know. The splodgy edge is where I sprayed underseal over the etch primer on the inside.
Here's the next job:
Any suggestions?
Robin
With regards to the tailgate just pull it out….
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
not much work today - I made myself a slide hammer to try to pull out the dent, but haven't triend it yet. I also went to the local VW agent, the same one who originally imported the car in August '79 - and he identified the colour from a plate under the bonnet as LA5V Azores Blue. Now I'll be able to order a spray can and touch up my repairs…
Robin
Drilled a few holes and used a self-tapping screw to pull:
A few more holes, used a bolt on the bigger ones, inserted from the inside on the end of a piece of wire stuck on with blu-tack!
Getting better:
Welded up the holes - it still looks like a mine-field:
A quick coat of paint,and that's enough for today:
This is taking a long time, and it needs quite a bit more work, but I do have the satisfaction of having tried it myself…
Robin
If the tie rod end doesn't need replacing, just mark the corresponding faces, measure between two clear points and unscrew the locking nut, then turn the steering arm with a 13mm spanner while holding the track rod end with a 22mm.
The steering rack gaitor just slips off after removing the spring clip from the outer end and a plastic zip lock (?) from the iner end, and replacement is the opposite of removal, as Mr Haynes says:
The second problem is going to take a little longer, as the wing needs to come off to do it properly:
Purists close this page now. This is not how to repair a lower front wing mount… but then this car is used every day, and if I take the wing off there is bound to be more involved repair work needed, so it can wait until spring:
That's all for today.
Robin
The only remaining electrical glitch is the pump for the rear screen wash, but I'm too lazy to dig around in my boxes and find a spare.
Robin
Robin
got a bit more renovating done today - the outer CV boot on the driver's side.
The boot was split, and Mr Haynes showed me how easy it was to change, but it wasn't, as usual. The first problem was removing the driveshaft. I didn't realise it needed a specal 12 pointed bit which I hadn't got. Four of the bolts came out with a hex bit, bu tthe other two didn't want to know, so I had to get a special tool - 15 euros for a set of five. They're called XYZ fittings, or something like that.
I still had to cut one bolt off with a disc grinder because it had no splines left…
Then, with the drive shaft off and the boot pushed back, the CV joint wouldn't pop off the end whichever way I tried - so I decided to remove the inner CV joint and change the boot that way. Having removed the inner CV easily, after simply taking off a circlip, one of the balls dropped out - that was fun trying to get it back in place without the others dropping out.
Then I washed out both of them with petrol, and realised why the outer CV hadn't popped off - it's the older version with a well-hidden circlip which has to be removed first.
Anyhow, after cleaning the two CV joints, packing with moly grease and fitting the new boots, the shaft went straight back on and all was quickly back together, with new bolts (hex fitting, not 12 spline) and thread lock to keep them in. I went out for a run and all feels fine, then tidied up the mess, grease, rags, etc, and found the circlip I had forgotten to refit on the inner CV!
It'll have to wait until the weekend, but I don't think there's much risk of the driveshaft pulling out of the gearbox in the meantime.
Some photos:
Here's the kit of new parts:
Here's how far I got before I bought the right tool:
If you've got x-ray eyes you can see the circlip:
All back together:
I only used the metal clamp on the wider end because on the narrow end it didn't grip very well so I used a cable tie instead.
Robin
PS See that circlip on the piece of wood in the background, well it's still on the piece of wood.
Like in the UK, you can no longer tell where a car comes from with its registration, which is a pity,
We do have a few advantages with formalities, like no road tax, over here, but don't forget that France is the country that invented the word 'bureacracy'.
Robin
I'm getting better at this. Today it took only 45 minutes to remove the offending drive shaft, refit the missing circlip, and reinstall:
Without the clip:
With the clip:
Next time I won't forget it…
Robin
another bit of rot repaired today:
Clean it up:
Cut out the rot and prime:
Cut a piece of metal to fit:
Drill a few strategic holes and weld them up:
As you can see;my welding is not very good. The gun on my Mig is very tempermental, sometimes it's perfect, then the wire sticks and it just spits. I tend to do a first run, grind back the welds, then do a second run to fill the holes!!!
Then etch prime and underseal:
This area is not finished, unfortunately, as there a scary bit right next to the rear beam mount, just behind this new metal, so I'll have a look at that next weekend. At least I'll have something to weld to!
Robin
About the MOT, it got through the French MOT with a hole there, so I guess regulations are not the same, and it's certainly stronger now even though it isn't finished.
Robin
I finally have time to play with my car, though it is being used every day. Last month I split a radiator hose, but luckily I saw the steam before it got too hot, taped it up and limped home. I've fitted another temporary hose, but will need a new one. It's the top hose from the block to the rad, for a '79 diesel, and seems to be quite hard to get. Any ideas?
Next on the line are the wheels. I fitted the 15s from my cabby with the onset of the bad weather, as the tyres are new, but the ride is not so good, so today I went out and found these:
They're actually cleaner than they look, with very little kerb rash and just the varnish and paint which needs doing. I've also bought myself an ebay wheel polishing kit, so I'll have something to do over the next weeks.
Should these wheels have centre caps?
Robin
