My mk1s...
My mk1s...
Epoxy Mastic thrown in there
Dug out all the old cracked sealer and re-sealed with 3m between the roof gutter and rear quarter too, but forgot to take pics.
Got the windscreen out, by completely ruining it Found a few concentrated spots of rust, could be worse I suppose. Was just hoping this car would surprise me with an immaculate scuttle
Welded up
Pretty immaculate now!
Almost ready! Got a week left to paint it
Getting there!
Im having a night off tonight but will pop up tuesday evening
The Mk1 Golfs older and better looking sibling……..
Fair play, top work going into this!
Quick question on the the epoxy mastic - I see you are applying direct to clean metal, but can you apply to pitted metal, say after you have cleaned up a area up with a wire wheel?
And with the 3m bag seal, can you apply over any paint finish? I have a mk2 i need to underseal but I have only removed areas of underseal where rust was present. Could I apply this 3m bag seal over the original underseal if I cleaned/de-greased it first?
Looking forward to more progress :wink:
Edit: What pls model are those wheels on the white mk1? - Always liked that mk1 8)
The epoxy mastic instructions say that it best adheres to blasted clean metal, but it is possible to apply it onto ground/sanded clean metal and even pitted surface rusted metal! As long as you prep the rusted surface the same way you would if you were treating it.
The 3M instructions say the sealer can be applied to any primed surface
So what I did was sand the metal clean, apply the epoxy, etch prime over that, and then apply 3M on top of that. Then as G-DUB has mentioned earlier in the thread, plastic primer is useful to put over the 3M before top coat can be applied.
Got 6 days to finish this
6 days eh! Why 6 days?
Nice job on the front lower strut brace to.
Are you on swdubs to?
I'm not on SWdubs no, I'm from the north west :mrgreen:
1st coat of primer
Flatted back and second coat
also where does the bag attach, im a spray painter and remember using this kind of stuff years ago but it was in tube that you put over the top of sealer on back panels etc
000dave000 said
Quick question mate the 3m sealer youve used what gun did you apply it with is it this? :
That's the gun mate, the bag twists on to the front nozzle.
P.S.
Massive thanks to Ben and Mike! Lads came down from Southport to help me finish this off! 8)
G60RGE, yeah, much satisfaction. Although I can't take credit for putting the paint itself on. Including buying all the materials and paying the lad who sprayed it, it probably cost around £500. But tbh, he is a pro painter so it was more than worth it. I'd much rather pay someone to do that part of the resto well rather than wreck it myself before I have enough experience. At the very least, being involved in everything and watching it all happen means I know the car is how I want it 8)
Refurbed grill, trim and badges, and P-slots added.
In its new home whilst I finish off the bits and bobs
Funny how all the bits I removed from my white mk1 about 7 years ago thinking I'll never want to use again have all made a comeback
Thanks to Chris, Winston, Josh, Ryan, Ben, Mike for all your help this weekend, proper lifesavers 8)
000dave000 said
good stuff what sort of price did you pay? cheapest seems be about £55? that about average, leaves a cracking finish!
I borrowed one :redfaced:
