Project bogey man. It's legal :-)
1979 mk1 Golf Gti (Dan)
2010 T5 Karmann Colorado
2012 mk6 Golf Tdi convertible
2019 Skoda Octavia Sport ( it’s Golf)
Fitted
Also stripped the engine down today, not sure if i have been mugged on it? thick grey sludge in sump, timing was 180 deg out, it was meant to have been a runner!!!!
All running gear is now done.
Brought a engine from a member here, 1.8 lump with kent cam, vernier pulley etc, started stripping it down today and found this.
thick grey paste
Also cam pully was 3 teeth out, timing was 180 deg out, 3 threads stripped on the vernier pulley, did a compression test to check valves were ok, down on number 3.
Removed cam to find its picked up :-(
Thankfully james is sound and has agreed to refund. so 2 steps forward and 3 back, 20 days to go and its going to be really tight!
Going to fit a mk2 engine now, strip clean and paint tomorrow, rather than fitting like I should of been doing :-(
The cam cover could be the cause as it was painted, when i had my covers were done they masked the breather mesh off to avoid this!!
matt black VHT, + a load of powder coated parts. new seals, sump, belt, tensioner, waterpump, gaskets (ignore the dizzy its blanking a hole)
Engine and block is going full matt black, even the carbs to tie in the green/black theme.
17 days to agm and im doubting its going to be there :cry:
Resealed the box, and fitted the 90mm cups.
old and new
New sachs clutch kit
Engine all fitted un minus carbs
Box took some cleaning, 1 day infact!!
How it sits now
Will she be ready for next week?
Very jealous :mrgreen:
Got held up due to the metal coolant pipe being a bit crusty, lucky i found a local motor factor with one in stock so thats going to be painted and fitted tomorrow.
Rads mounted, new hoses and pull fan
Collecting bumpers tomorrow night so should be running and ready for mot by end of the week :dontknow: i doubt it tho
How's the rot box going?
Could do with a spit/jig soon if you hear of one going
