my Mk1 20v 1.8t k04 hybrid dyno results 16/08/2015
Mk1 20vt Megasquirt attempt (and it runs woop woop )
Ooh I'm liking this.  :)
I was looking at those frankenturbo's the other week.
Be interested to see how you get on with it all.
fitted manifold today suprised how much room there is. had some manifold nuts machined with 12mm on the back fitted nicely. turbo next
Looks great mate. Did you get some pics of the expansion tank mounting??
here they are. mounted the tank using mk1 golf radiator brackets just flip them upside down. 1 mounted on suspenstion tunnel and 1 inner wing. also smaller washer bottle fitted so i can my coil pack in there
Lovely, thanks mate.
Mathew (trackslag) needed a mk1 to make a k04 downpipe for his range of downpipes. so i agreed he could take my car and use it for template. fair play to him traveled from newcastle today and i had to quickly fit the rentless manifold and turbo . took me 9hr to fit the manifold alone. hands cuts and battered never again i advise any 1 doing a rentless manifold to take the head of. two bolts i just couldnt get a spanner in there . hope to have it back weekend with its new downpipe.
well matthew (trackslag.com) sent me some pitures of the k04 downpipe. they made for my car and for there downpipes . they manged to get a 3 inch downpipe which is just amazing. comes in two pieces for easy fitment. £295 deliverd to your door next day bargin . here sum pitcures
I've got one mate on pre-order ;)
get a v3 manifold you know u want to. lol let me know if you want 1 i direct you to rentelss uk dealer. you got engine out of car aswell best  k04 mod out there :)
Got one already mate in my shed waiting for Sunday to be fitted  :twisted:  :twisted:  8)
sorted
Pete what heat matt did you go for behind the turbo and manifold?
i brought this
http://www.ebay.co.uk/itm/320690415183?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
loads left after cutting it. use the rest on heater matrix pipes. also as you going to run rentless manifold you want a heat shield just behind the  rocker cover gasket and coil packs so it dont burn it. there are 2 bolt holes in the head where you can fix it to. i be doping my weekend so i post pitures
OK cheers mate will look into it. Also I am in need of some bolts to fix manifold to turbo. Which size did you go for?
you want turbo studs instead of bolt easya to fit manifold to turbo as 2 u wont get 2. you need 3 studs part number
n90767801  58p each
and cooper nuts
http://www.ebay.co.uk/itm/380507393822?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
and get some m10 nordlock washers aswell to keep it tight
NO I meant which bolts are you using for turbo to manifold mate. There's 3 holes. One has slight cut out to get to, the other is easy and the 3rd one is a right pain. Which bolts did you use for them?
didnt use bolts used
studs the same as where the downpipe  attched to.. you wind them into turbo using the 2 nut method so they are tight  and then slide turbo up into manfoild and then use the cooper nuts i take a pitcure of my trm
not my pitures but same as used by me
image hosting
pic hosting
picture hosting
Ah I'm with you. Is it secure like that? I'm guessing you didn't use bolts due to access issues.?
U won't get a bolt on 2 of the holes
Use nord lock washers
I told you we don't need bolts and that the k04 is stud mounted………….
