my Mk1 20v 1.8t k04 hybrid dyno results 16/08/2015
Mk1 20vt Megasquirt attempt (and it runs woop woop )
rennick said
nice dude. just starting mine get the engine Saturday then full steam a head. how much in told u spend on the ecu and the looms. as dnt wanna go down qpeng route £££.
had ecu built by Toyotec  on cgti and rubjonny built my loom pm then. plug and play
JonP said
did you fit the new shifter tower yet on the gearbox?
yep all fitted with a polo gti 2006 selector(cables are a perfect lenght) and it feels like a brand new car changing gears. i get some pitcures up trm
nice one dude dnt suppose u have there email address do u?
check pm
sorted out a garage now. took doors bonnet wings all of for easy access as its tight in there.
start stripping every thing of today to get ready to install some forged conrods. never done rods before so be intresting. had to finish early due to the 2 sump bolts by the flywheel. there on the wonk need to get a small thin long 10mm socket. plus got to go and get my rebuilt ko4 of mk1234golf. will update when my rods come.
well what a day finshed fitting the forged rods all went well just followed the youtube 1.8t engine assembly videos . now just waitng for turbo and manifold from the states
well where do i start been a hectic month. when it came to install the forged conrods i was shocked to see that the ebay engine i brought had a cambelt failure sometime in past. engine ran fine when i first turned key drove it from garage to outside where i was working on it. seems like it had a cambelt failure and a another head was just put on. all sorted now as ive rebuilt most of here some pictures
old pistons
cylinder 3 bore
head some bent valves
bores honed
pistons from a low milage passat aeb engine same pistons as agu 20mm wrist pins
new pistons installed along with forge rods and racing bearings ( see my wallet its low :) )
cylinder head rebuilt by a m8 of my had new
new exhaust valves
new valve guides
valves remachined
head skimmed
dechoked
new tensioner
epytec g60 adaptors
so this weekend fit it all up
shifter cables via bulhead as i like shifter high :)
engine all fitted up just need to fitting timing belt and sort loom back.
plumer heat matt
Looking good matey pm where you got your fuel line and end cap's from they look loads better than what i have.
pm sent
well finally my turbo and manifold are here. so now i can finish the car off and get it on the road. i went for a k04 hybrid frankenturbo f23 with a rentless v3 manifold. also on the way from frankenturbo are 550cc bosch injectors. heres some pitures of what came
f23turbo(boxed)
cremic coated f23 hybrid turbo
came with oil/water lines aswell
start fitting it all this weekend :thumbup:
That's awesome mate. Bet you're pleased with it. Good luck fitting it all.
Looking forward to more pics when it's all fitted up.
Smudger
my injectors came today ford racing bosch 550cc ev14 with ev1 adaptors 80 quid for the load from franken turbo bargin
picture hosting
image upload
PM sent to you with a few questions :)
Christ! 8O  lol
pm replied :)
jonp when your one ready
when I have a working ECU, current one is dead :(
JonP said
Christ! 8O  lol
Few questions re intercooler pipe routing and expansion tank. Nothing major ;)
