mk1 20vt and mk1 PD
mk1 20vt and mk1 PD
I want to do that to my servo mate
any tips
cheeers
Diesel Possessed
A97JCE
Feeby
what sort of tips u after mate? the mounting and installation guide are in the instructions  8)
me: www.facebook.com/mkoneman
work: www.facebook.com/obdworks
club: www.facebook.com/dubcluboxford
instagram: mkoneman
Very nice mk1 :clap:
James
started preping the bay for a bit more welding  and smoothing as the clutch, accelerator, brake holes will no longer be needed
and picked up some new fuel lines today
instagram: mkoneman
Excellent work there fella 8) ,like the front mount you made top job.
Couple of questions regarding oem management
 is that a agu  ecu and loom?
do you need to run the clocks or has that been programmed out with the immobiliser defeat?
 Who  did you use to remap and defeat the immobilser?
will it make any shows this year ?
76 ?
78 gls
83 gti 5v
cheers mate, its aum engine and management out of a 2002 golf gti, yeah everything is removed thats not needed and if you need it done contact crazyquiff and they can sort you out  :wink:
made good progress on the pedal box today
all jigged up at cq yesterday then seam welded today
i also have to make a way of fixing the pedal box to the bulkhead now as the holes will be welded up, so i started making a bracket to weld in place
also had a little delivery from the paint suppliers today i cant wait for my Christmas break now
instagram: mkoneman
i should have this done by the end of the week with any luck   :dontknow:
balance bar welded on to the brake pedal
i welded the accelerator mount on and gave it all the 1st test fit together and it all seems to fit nicely i just need a trial fit in the car to check clearances etc
instagram: mkoneman
also i needed to fit a brake switch for the ecu and there is also a wire for the clutch (its prob not needed ill connect it anyway) so i welded a extra little plate on and mounted a pair of micro switches to the backs of the pedals to keep them out the way
instagram: mkoneman
foxymk1 said
your work is awsome pal,, be my friend plsssssss
foxy
He's mine all miiiiine - meheheheouhow! :manic laughter:
Crazyquiff's Mk1 Golf Parts Emporium
www.golfmk1.co.uk - you know you want to….
crazyquiff said
foxy
selfish!!
That's just car porn at its best, well done that man!!
Deffo from the darkside
Mate your install game is extra tight deffo from the dark side!!!!!!!!!! 8)
hahaha fight fight :lol:
thanks for the comment
the pedal box is almost done at last lol
all that's left to do is mount the fluid bottles
the interior is 80% out and its looking less like a complete car by the day
the wings off too for the hidden loom
bit of bay welding next week i think  8)
instagram: mkoneman
i want the pedal box. i want the pedal box.
Mk1GTi
Rallye Golf
Mk5 GTi
Mk7 GTD
Jim's pedal box is based on the crazyquiff one - I'm running a pedal box on my GX at the mo, with hydraulic clutch (ABF with 02A box).  We also have a remote servo on the front brakes only for testing.  Have adjusted the bias accordingly.
We're bulding a pedal box for the 20Vt we're doing at the mo with the flybywire accel pedal too…
Rich
Rich
crazyquiff , how much for one of those pedal boxes??
Rich
garyc and smokeybubbles - prices are here - Pedal Boxes at Crazyquiff's
Rich
stripped the gear shifter down today for a bit of a refurb
then a bit of chopping to the tower to get it to fit into the mk1 hole i gave it a mock up into the test panel i have
looks a little industrial at the moment but it in its fit up stage
instagram: mkoneman
cracked on with the smoothed bay tonight  :D
plates welded in
all smoothed off
ready for a flat off small skim of filler and then time for paint
instagram: mkoneman
