Kamei Retro Racer mk1 build
Got the car up in the air & did some checking / measuring:
Drilled an 11mm hole through the double skin area of centre tunnel:
Tidied up & ground of any burs then soaked any bare metal in etch primer.
Cleaned area for plate then held it in position & put eyelet through into it & tightened:
Driver side Finished:
Then get the disc cutter on the ends of the front half removing about 2cm:
I tried pulling them in with a strap to see the difference and as you can see RESULT!!! they look much better:
Just need to spend time on it drilling new holes for the front section.
Also put some etch primer on one set of seat brackets:
Had one mishap the other day when i bumped my head on the steering column when the wheel was off & snapped this piece off that normaly rubs against the wheel (for horn i think):
Not sure if it is hard to replace/repair?
Drive shafts had all new CV ends fitted then i repainted them:
Few bits on the gear linkage also got a dab of paint:
Picked up a crane for the heart transplant (thanks Craig "Altern8"):
An old pic when it came back from the bodyshop:
http://img.photobucket…ack%20Car/Photo-0430s.jpg
Was hoping to have had things done a lot quicker but so many other things going on at the moment so it's a bit of a struggle sorry folks :redfaced: .
and on the car
cant really run them without berg arches lol the law dont take too kindly
just thought they look similar to the ones in your pics they are of a chevy camaro lol
the front are 14x6j and the rears are 14x7 an a half j polish up nice too, good dish on the rears
also i had to find wheels that looked a little like the original ones for the finishing touch though they were a smaller diameter as well:
http://www.clubgti.com/forum/showthread.php?t=208693
Mine (though they are BBS so pic has cap off):
some of these would have been nice:
though hoping eventually to have mine like this:
mk1 golf - resto
mk3 polo breadie - daily banger
fthaimike said
VAG
doh!i went to vw an got told they were either obsolete or £200! gsf it is then haha!
mk1 golf - resto
