My mk1 resto
My mk1 resto
:clap:
My Build Thread
the gear linkage rebuild kit from GPC - only 2quid! comes with all the new bushes and washer etc to renew the old items - the housing with the red bush in it you see here was just put in rust bath (DEOX C from Bilt Hamber) then painted with gold paint the motor factor mixed up - it is a good match for the yellow plate that new parts come with and it won't flake or rust like that yellow plating does…
Fitted the wishbones and rod ends - wishbones got superflex rear bushes and just standard fronts
Fitted the aero cap from Newton Equipment -
Also got a new filler neck bent out of s/s and my unlce braised a breather on it and also he decided it would polish up easy enough and after some light sanding and a bit of buffing it came up blinging well…
Then made a mount to mount the fuel pump out of a bit of scrap stainless and well i polished it too! just used the existing mounting points of the chasis.
Then got some heat shield from Agriemach - it is real sticky and is good for a painted or smooth surface - hard to shape though as there is a grain which you cant run against - the wee wrinkles look worse than they are.. but worth the hassle as i don't want to wrap the entire exhaust - as it'll get a bit of polishing no doubt! Also refurbed the shift rod and got a new rubber boot.
Then mounted the axle and shocks
Also wax injected the whole car - so she shouldn't rust in a hurry!
thats it so far - next up is nipping up the brake lines tight and putting in the goodridge lines/front hubs/shocks etc…
thats all for now
Life Member
dubboy said
Are you going to use the car much when its done?
I'd be too bloody frightened to!
Excellent job mate and another inspiring update! Keep it up!
My Build Thread
VW's standard isn't that good even now! :y:
BACK SOON..............
Keep the great work going. Do you have a end date of when you think the car will be completed?
dubboy - it will be dry day summer use only - taxed for 6 months of the year sort of thing
it will be used! think stone chips may be an issue!
looking into that 3m stonechip film stuff for the front end…
Carbs4ever said
Thanks again for the kind words.
why don't u get a complete front car bra for it - they are really worth it…
Guest user
I'm looking at making a stand to get the car higher up in the air, I was wondering how you raised your car onto that stand that you made?
Cheers!
Like your web site mate. Option 1 could look quite cool - would certainly be unique with short doors!! Keep us posted
intraclast said
carbs, firstly fantastic job, I'm just starting my own restoration (http://1982mk1golf.blogspot.com) and this is inspirational stuff.
Cheers!
Great blog there - I'll be keeping track of how your resto goes!
To get it into the air more, what about a decent engine crane, lifting at some suitable points on the body?
I was planning on making an all sing and dancing car tilter, but have decided against it as it will take too long to make (and get right).
1983 1100 C
1983 1100 C
