mk1 20vt and mk1 PD
mk1 20vt and mk1 PD
Just read this post from start to finnish!  Well Done … awsome car.   Really like how you have re-engineered alot of it!
I am currently doing the same conversion on my mk1.    I have the standard ecu (immob defeated)  Im finding it really hard to wire the whole thing up.  Dont even know where to start!!!  I noticed you said crazyquiffs will modify  my loom for me? Tht would help!
cant wait to see this car finnished
thanks mate  8)
yeah we would be able to mod the loom, what engine code do you have?
today's job was to relocate the N75 valve to a more hidden place
i purchased 2 self sealing fittings  from revotec and got fitting
these come with a punch to make the hole in the hose
fitted into the boost pipe
then the same into the turbo intake pipe
and all plumbed up and hidden away
i also found a stockist of the proper single ear clips in stainless so i replaced all the clips
me: www.facebook.com/mkoneman
work: www.facebook.com/obdworks
club: www.facebook.com/dubcluboxford
instagram: mkoneman
a few pics of the new rear lights i finished after making some trial ones
2000grit flatback and another layer of clear
engine should meet bay in a week or so  :D
instagram: mkoneman
Love the rear lights!
My engine code is AGU. What modifications does the loom need? all i will need to do is wire it up to the fusebox then?
My car was carb so i need to wire in a fuel pump relay also.
Help would be much appriciated! i will disconnect the loom from the engine + package it up ready to send to Crazyquiff.
I like your intake , the standard one is alot more restrictive! think i may aquire a few of your ideas.
Loving the lights mate, are they just the standard lights with tint spray on them? or are they all red aftermarket jobs? I added you on facebook too btw haha  :redfaced:
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
they were clear rears mate then I tinted them  8)
little bump so this doesn't get lost lol
bay painted its all back on 4 wheels and ready for the engine early next week i hope  :redfaced:
steering rack all mounted back up with the solid mounts
instagram: mkoneman
looking lovely chap!
pretty sure for the diagnostics you can run the k-line from the ecu direct to the VAG-COM port, you dont need the clocks or either of the CAN-BUS wires. Kline wire is from pin 43 of the ecu, or pin 1 of the orange plug if you still have this on the MK4 loom. run this direct to pin 7 of the diagnostics port and you should be in business. the only reason there is a k-line from ecu to clocks is for the immobiliser function, the clocks then have a passthru for this wire to the vagcom port :)
with the SAI delete you don't need a resistor, this wont do anything to prevent the code that comes up. to make sure the code doesn't appear it needs coding out of the ecu, as it does complex calcs based on lambda results to determine if the SAI error comes up, rather than checking the SAI wire to the relay. the wire is simply a trigger wire to the relay, the ecu cant sense anything from it see.
good news is afaik the SAI code wont actually effect the engine power if its flagged up anyway :)
good info there rubjonny thanks, i have done a few of these aum conversions now and have never had success with running the k-line straight to the obd port, the clock solution works so for the odd time it needs plugging its not a issue  8)
right time for business
here it is……………..
engine in
sat on all my custom mounts no problem  :D
most of the pipe work on for mock up
the engine is 100% wired up in the bay and I'm half way into the extended loom
a few random shots
the sump on full drop is quite low too  :lol:
that's all for now  :mrgreen:
instagram: mkoneman
Awesome. But every time i read an update it makes my car look more and more inadequate...
Mk1GTi
Rallye Golf
Mk5 GTi
Mk7 GTD
this is amazing  :P
ok cool will bear that one in mind :)
wow that engine is porn! i want mine to look like that :-(
Top work !
1.8T CABBY
thanks everyone  8)
with the engine bay wiring done i moved on to the hidden loom in the wing
I'm using 2 looms spliced together to make one long one  :lol:
part way in it looked a bit of a jumble  :x
then bunched up and mocked into place
this is how it will stay until its up and running (in case of any alterations need doing) once all is ok ill loom it all neatly
ecu all mounted up
next up will be the internal wiring  :D
instagram: mkoneman
got a few more adjustments done today
with the intercooler mounted up i tried the crazyquiff boost pipe on but the stock outlet on the intercooler needed angling up and in
stock end
pipe cut
then i tig'ed it into place
and all fitted back into place and it fits spot on  8)
next i started on the final engine mount using the oe mount Ive welded new mounts on for a mk4 style dog bone mount
ive now mounted it up taken some measurement for the 2nd half, watch this space
instagram: mkoneman
My goodness thats pretty!  8O
Well done dude, looks sooo sick. Cant wait to see it rolling, although it may upset me slightly!  :mrgreen:
haha cheers dude  8)
hows yours looking?
instagram: mkoneman
Slowly but surely she's coming along, when I say slowly I mean slowly!  :mrgreen:
lol when dont they
give me a shout if u need a hand  :D
instagram: mkoneman
Thanks man, I know you love wires so i'll be sure to hit you up!  :wink:
Looks mint so tidy. Top Bloke as well :D
