Car stuck in gear
I did not have a slide hammer so once I cut a thread in the old bush I used a bit of threaded bar and screwed it into the bush then used a socket as a spacer and screwed a nut and washer onto the threaded bar to pull the push out.
info from broke VW.
020seal
To be honest, the hardest one was the output shaft seal - that took some real effort to get out.
I also did the release arm seal as mine was shot.
Search VW 020 gearbox as if you add Mk1 Golf the "scene tax" sometimes gets added and the price goes up…. Shop around as it’s the 1st link I found.
Regional Host NE
in british leyland cars as well as vag
I noticed that when I had fitted the first seal, it becomes alot more difficult to turn by hand. Without any flanges fitted, I can turn the diff axles very easily, but as soon as one of the flanges is fitted, I have to get a hold on the flange to turn it.
I hope its due to the pressure on the bearing, and nothing I should worry about?
The new old box runs nicely, and no leaking.
The part that I need is the number 45 but I can't find it anywhere…
golf 1 gear lever parts - Pesquisa Google
T
https://www.ebay.co.uk/itm/192356261364?_trkparms=ispr%3D1&hash=item2cc9539df4:g:XrkAAOSw~FNUZQeM&amdata=enc%3AAQAGAAACkPYe5NmHp%252B2JMhMi7yxGiTJkPrKr5t53CooMSQt2orsSd3M8ngECaRA0SmyU4KT%252FnkEkUW945FmpyXDSnQs4dWNz5nAlW0so%252BXsbR6FyBGksHnEn5joRqs7BNBSI84qxueFN87SWioZg%252BJqQj9x6mx7ZnJedqONvQtVNNnIzANjMuCdG%252F%252FDBe07IVWz81YY3gN4NBYIm3Y6j%252BuEX%252FqTgXjybp8%252BuU9K94951IxU9f2uJa32iNo2WAaqctspBHDeXPIhTPCKuWrXfXV0TA487J6nq8A16ZXy%252BLNBjySrwRHqqfHNw6USlxpS3RaPRgfry14CxkPHqtLDJwszPJCDkSPWx69B6EBIulEh2S8TP12P2s1CONxeoa77ske%252FRjFlja1WC5GvG3KHOUWsTbyyIqH1IUu2jOtM4Z1CwUh4yhB00vMz6qSPPdFnQ0Qe%252BfijY7WsSD6pBXnxO4ZvXr%252FvryVFh2WrgjolxOlr0vFxLMNkQ%252FUEazVuFr9pjfuAOOFfKGnXKdOb8UqB3A3NpsN34%252BKnvrEOHgZ0vDKqlk7cMT49W6kskYtz7WJh8Mg7Knzu8%252BNKfr1PRPgrKpNLFdVbMs0Gsk2wyQjo0Hm0KkCu73Aly7laRGy0CjrI0keTWa0GmBKLdxVR%252BdxWlV%252Bbg9hA%252BsYR2NwzXfSe9rJjnvrxdZLZt9tfEWx8QMrXiVGF%252Fi2lXzs%252BAM8std2E9u3vNwRzrm2IdBlb%252FUOTuj9S4m2bm7MJNEe0cO%252B0MTQxyjixJgRv1isqoc0TqJNMpBviAGVPqnkWOtWq0Shf8Zr04U%252F6P9tC7snslJt2VcLroVxjEDNE85goUdZurUq1OH9fhAux8%252Bgl%252FpdnhEVtwk7UdobWEjpJX%7Cclp%3A2334524%7Ctkp%3ABFBMuvv-vcZf
Or here
https://www.classic-vw.co.uk/mk1-golf-gear-selector-pivot-171711247-4031-p.asp
or here
https://www.autodoc.co.uk/meyle/2116722
http://cabby-info.com/Files/RepairingStopFinger.pdf
https://www.google.com/search?q=tringlerie+boite+de+vitesse+golf+2&prmd=xivn&sxsrf=AOaemvLn7flPLmi_4IELO7LEyhlVFSb1dQ:1641556805320&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjJoonSy5_1AhWCSfEDHfaRCxYQ_AUIGCgB&biw=428&bih=751&dpr=3#imgrc=t2qcpbucgMERkM
171711247 VAG Bush, shift rod bearing.
https://www.heritagepartscentre.com/uk/171711247-bearing-for-gear-lever.html
If you start using the ETKA you can get better part numbers for it.
https://volkswagen.7zap.com/en/rdw/
If you could take a picture of the part on your car and where you suspect it being bad by circling it that would help us all assist you.
If that place is indeed bad, then you are looking at probably locating it at a breakers.
