Instrument cluster repair
(In Topic #220349)
Rev counter stops working and the MFA screen goes blank when i turn the lights on, the back lights don't illuminate when I turn the lights on and the oil buzzer buzzes for fun. The MFA screen would also benefit from replacing as its a bit dim to read.
The cluster itself looks perfect, no obvious damage to the blue flexi board on the back, I did have some of the components replaced on the oil buzzer board in the hope that would solve the buzzing.
Currently got another set in but even they are iffy with a worn connector plug (works its way loose ticking over) and a oil buzzer that will randomly go off. I have fitted VDO gauges and that reads good pressure with no drop when the buzzer comes on so I'm pretty sure that the instrument cluster is the issue.
Your basic auto electrician won't really know where to look from my experience.
But hopefully someone might be able to come back to us with an answer
Check to see if that's missing, hanging on by a few threads of wire or hanging off completely.
The 10V stabiliser can go iffy.
This feeds supply to the clock.
Make sure that the cocks are earthed via the rocker cover to the coil mounting bracket bolt.
On DX engines.
Poor clock connection can be cured by cleaning the copper pads on the foil and then wrap a few turns of electrical tape over the plastic nib it fits over.
Once it’s connected it’s a tighter fit.
Cheers!
The bulbs all the rest are on the 12V circuit.
Bulbs go bad, that is a sad fact, and I found that if I haven't changed them in a few years I will replace them all out of hand.
The buzzer goes because of a possible flaky connection,
If you haven't Plumped your connector, then you need to add a dedicated ground splice to the Brown wire.
But you need to verify that you have 12V at the 10V stabilzer, to pin 2(brown) ground.
