vw golf cabriolet 85 US Spec restore - 3279A
more progress on the front seats. Second seat back section complete, even got my base metal back from being powder coated.
One are I am not happy with is the head rests, can see in photo below the new covers just don't fit well, so going to redo them.
So with new bolsters, you have to cut these to make it perfectly. Notice extra form on new ones at bottom, so cut these and so there is extra foam at the rear on the underneath, so cut this out too.
parts cut out of new bolster to make them perfect match to originals.
pulled the base foam together to make sure all fitted properly - very happy with results
Then install the new leather onto the new side bolsters and for about hour I am fighting to get them to fit nice and tight with zero luck, then I went and measure the new to original covers and bingo the new ones are 1" longer so I need to correct that and then retry installation again.
Well I have some work to do on head rests and side bolster covers and then I can complete the seats. Next update will be once I have these done and installed in the vw.
I also did some outside work on vw, I painted the side indicators to match the vw color. Interesting to note i found each corner was not even wired up!!
I also removed the arches and have new ones coming.
I also removed my front grill to change the color of chrome to Vw GTI red.
My european small ducklip turned up too, will install that this weekend and update once have grill done as well.
OEM side indicators;
Paint!
and painted…
and the end result on the car
and the front grill off! thinking should I upgrade my lights or not?
I did remove one other part from outside of the car to paint black, can you see what that is?
Here is my new european lip and compared to the GTI one. I prefer the European version - mainly due to when I put coilovers on I won't loss it!!
The GTI one will now become Art in my office!
and the car is all covered up again..
Did a few things….
Install of new euro lip
The right securing parts - what some people use on left…
Jack vw up a little… makes life easier when using tools to get securing parts in to hold lip in place
Hold the lip in place and place the middle screw and washer in and repeat working on outside in, do not screw them in completely, once you have all of them in place then slow tighten up. Don't over tighten or you could damage the lip.
and all done.
Then onto the front grill
I already took off the grill to take the metal off to repaint it. Once off gently pry the little tabs back off the plastic grill to get them all.
it was a really nice hot and dry day when I did this. I made sure all parts where secure so I could paint them. Before this I wet and dry sanded them down and de-greased them. (no sponsorship was given from shipping company but the box worked well - so thanks!!) :laugh:
First primer coats x2
Then onto the correct RED color paint.
While waiting for the paint to finish I cleaned up the grill itself..
I actually left the grill parts painted overnight and then put back together in the morning
All back together again
and installed again on the car, overall I am really happy with the it.
Additional changes on outside
Adding the CL rear arch covers;
All new parts and correct parts to hold arch in place;
installed!
now do I paint the side mirrors black or leave them white?
and what car looked like when I first got it.
Few small projects happening;
1. lower and upper strut braces, the upper one required same cutting and welding, but that is ok I enjoy little bit of fab work :laugh:
2. Finally got small rear arch clip so installed that
3. Took off the rear badges to clean up and re-new them
4. Fixed driver side handle - metal clip inside the door broke!
5. Scored deal on front replacement axles
Strut braces lower and upper, upper one is hitting the throttle body and goes over radiator expansion tank opener. Easy fix I will adjust the setup of this. updates on that next.
Rear arch cover clip arrived, now drive the cab without if flapping around!!
Rear badges needed taking off and applying new stickers to make them new again!
New stickers for badges;
Broken in door handle clip
New parts arrived, ordered from Europe… these are hard items to find for sure
Front axles, all part of new parts for front setup, so I can do new suspension, arms, brakes, etc in one hit (this will be winter projects)
I am on the hunt for BBS RS Wheels too 15" 4x100.
Last edit: by madone_si
Managed to complete the rear badge refurb
Take you time as each letter and VW symbol are individual - use small long length pliers to pull off and place on badge lettering
Painted the Cabriolet badge white
And installed :)
another job done.
Still waiting on my final leather to turn up so can cut and do my Recaro seats.
Finally got my new materials to finish off my Recaro seats and so the last few weeks been busy creating the new bolster covers and head rests.
How Seat was before
and now finished
and the Real Recaro covers and new handles
New supports (originals ones where ok, will be selling the originals ones)
This weekend I am rebuilding the bases, been powder coated, all parts cleaned, new spring, new Bosch Motor, upgraded to later VW/Audi model, so much quieter now.
Just got some wiring to redo and then can install both of the bases onto the seats and into the VW.
and finally my new shoes turned up - brand new custom lips, restored centers, new caps, bolts. Very happy with the staggered setup
Sharing some research I did on Bosch power seat motors and options if your original ones dies.
Seat motor (Make: Bosch API v12) spec;
0301-002-405 original VW
0301-002-5xx later bosch model fits too VW
8E0881183* (C, D, E) - VW
Rear Seat Lumbar Height Motor Audi A8 S8 D2 - Genuine Bosch - 0130-002-564
BMW lumber height motor Bosch unit 0130-002-400 also near perfect match to original VW ones
Original 0130-002-405 (on top)
Audi version 0130-002-564 - bigger motor in length and cable connectors are different.
BMW 0130-002-400
The car looks so much better with the euro bumpers and I'll say white door mirrors.
Those seats are fab but not sure on the electric motors etc as it's adding weight and at the end of the day how often do you move the seat?
Mark1gls - thanks for kind comment.
Electric motors come with seat so why not, plus I'm not concerned with added weight, this is not race car  ;) yet!
It's a nice touch having electric seats and it's your car so go for it…. :thumbs:
Keep the updates coming.
yeah I thought so too  ;)
yeah trying to get more updates coming, lots planned for this winter, all parts are in just time and hoping for no rain at the weekends!!
finally bases screwed into the seats themselves.
one of the key things I never see people report on is when putting new seats in or rebuilding, you must grease up all the seat runners and plastic parts that seat moves on, that including seat base parts too.
Passenger seat in!!! nice compare of original to new
seat runner cover
May wonder why not head rest, its easier to install without it. I will do next update with full interior in - both seats with head rests.
So finally have second front seat in and the interior is now 95% done. Due to raining I could not put headrest in, but see below on rebuild of those too.
Before
and the money shot!
Headrests metal needed cleaning and protecting as well as the headrest supports.
wire wheeled the metal to clean all up and used Metal ready and degreaser (POR15) in prep for paint
all painted and protected with POR15
Finally the interior seats are complete and all together! Heads rests are in place…
I also got the gearstick gater and hand break matching leather
I also have a new steering wheel coming, which will review little mod'ing and then I feel the interior is complete and I can move onto my winter projects of suspension, running gear upgrades and then new wheels install!!!
It's all coming together nicely and looking good  :thumbs:
thanks Mark1gls, it sure is.
My Christmas gift to myself!
Worked on Gear stick gator cover
Original one is actually in great shape after a little clean.
took it apart - clips rusted up
new cover
Put new cover over base (plastic) and added new nails and restored the rusted clip and POR15 them
Completed and compared to original
Also got my new door handle covers
More coming soon on changes to new steering wheel.
Gear stick gator installed
and gave the VW a clean!
Also noticed this heater lever came off way to easily, is this part actually broken (white plastic part) or is this is how its meant to be?
VW heater fix
So with top heater lever not working properly, dismantled the dashboard and found the issue, which is there is plastic part that has broken (Heater control pivot broke) Reading up and being informed from others on another forum, this is a common issue.
The white part in pic should have lever on top and a black plastic holds it in place and that is what has broken off
I followed this process to learn the fix and process (big thanks to Briano)
https://www.volkswagenownersclub.com/threads/my-heater-control-pivot-broke-cabriolet.46441
So here is what I did to fix it.
Once I got the unit out (not the easiest thing to do!) I inspected everything and gave everything a good clean.
In the above picture I drilled through black plastic part that holds the pivot parts in place and placed a bolt, washer and nut on the end. This will help fix the problem.
Added the white plastic back on, added white grease to pivot and moving parts
added the broken black pivot plastic part, now with drilled out hole through it to put the bolt, washers and nut through it to hold in place
Bolt installed from top with washers
Underside showing washers and threadlock (blue)
Nut installed and tightened up enough to lock but allow the pivot setup to work for both levers
Then installed the A/C lever and added grease. I placed a washer underneath ready for install as this is known fix for common issue of a-c-slider-pops-out-of-place. nice easy fix!
Next update, unit install in dashboard and time to do flush, clean and fresh coolant install (including Radiator inspection, replace thermostat and check all coolant pipes!!
