This is where it all started for me!
Dano said
It was tighter than DjEv's wallet come pay time for the Germany purchases!! :mrgreen:
If I could borrow it this week if be very grateful… Please post.
Can't believe it was that tight!
I'll post it tomorrow.
Life Member
Had to take a hack saw to it then a bar to chip away while hoovering the bits out as we went!! No bits went inside!!!Yomp said
Life Member
I small water leak revealed that the pipe had cracked and was leaking at the bottom.
Nearly there though.
Life Member
Life Member
Got a 'Hello, are you in the Owners Club' from fellow owner and long time absent member benandemu . Had a good chat and off he cycled! Thanks for stopping Ben.
Life Member
And fitting a 1984 year Blaupunkt radio cassette. All works well except the electric aerial catches on the garage door as I drive in!! Looks like I'll have to carry on pushing it in for a while!!
Fitted a new rear view mirror too to get rid of the old brown blotches mine. Hopefully there'll be less vibration and more rear view!! The new Bosch 075 S4 battery is being maintained by a CTEK trickle charge battery charger.
Now the hunt for a new large capacity washer bottle for the headlamp washer system to match the new expansion tank!!
Nearly match fit for Ultimate Dubs now.
I take it your electric aerial is wired directly to the ignition? is it not possible to have it to the radio live or a dedicated switch?
Life Member
I take it your electric ariel is wired directly to the ignition? is it not possible to have it to the radio live or a dedicated switch?
I've pondered on that one Tony. It would just be another switch to flick when I got out - and I'd probably forget, next thing a broken aerial.
I can live with it as it is.
Thanks Dave. Cheaper than buying new at £82.00 a side!!!
Life Member
He glued the trim back in place (I tried different types but couldn't get it to stick), filled the cracks with a bit of compound and then textured it up. Finally a light spray with some kind of plastic paint.
I was nattering on so much well that I forgot to ask him to do the centre console scratches!
Life Member
Purchased from www.classicparts.de
Part number 171 955 453 K
And dealer plates etc from www.dmb.uk.com as advertised on the site to the left <<<<<<
Life Member
Life Member
Clocks out
And following the thread in the electrical FAQ section…
View topic: Help - Main beam warning light -FIXED UPDATE- - The Mk1 Golf Owners Club
It worked a treat.
Life Member
They do work. Whatever the plastic insert does it makes the doors sound "just like a Golf" as the advert says. A solid 'thud' as they close has returned.
Life Member
Hairyarse said
Did the old ones undo easily? I remember when I did mine they needed a ridiculous amount of welly to get them off!!
They'd been off for the re-spray in 2011 so were pretty easy to undo. £23.00, should have done it years ago!!
