Pistolpete's Mars Red Mk1 GTi restoration
Restoration thread for my 1983 Y-reg Mars Red GTi, non-sunroof model
Very pleased with how this all looks now its rebuilt.
Last edit: by Pistol
This is the full set-up for yellow zinc plating.
And my first attempt on the oil cooler bolts/washers, as well as the big washer for the anti-gravity valve. The process seems to work pretty well, and the end result is definitely down to the original standard of finish on each part (i.e. the big washer was not perfect when it went in).
Hopefully I can get this even better as things progress. My dad has a power supply I can use, so that will be for the next batch.
New Automec cunifer brake lines run in with new brake force regulator, and the fuel tank installed with refurbished tank straps and all new fasteners.
I have already bought a set of Crazyquiff's stainless braided flexi fuel lines, however I'm wondering if I would be better to fit replacement hard lines whilst I have the shell stripped? I see Classic VW sell a steel line kit now. Might keep it more original looking. Just wondering if anyone else has gone this route, or should I just fit the braided lines and be done with it?
The reasons I went cunifer was that I was worried that the braiding on the Crazyquiff lines would eventually rub through the under seal since they are too big to fit in rubber grommets and that I wouldn't have problems with rusty fuel lines in the future.
So more progress this morning, I've now got the rear axle installed.
That's it for now, next stages are to complete the brake pipe connections at the rear, hook up the rear brake compensator valve, handbrake cables to fit, filler neck (waiting on the correct size of stainless hose clips) and then start installing the fuel pump, accumulator and hoses up to the front.
Reg Kevin
Gesendet von iPhone mit Tapatalk
Had a real struggle getting the fuel tank filler hose fitted, but got there in the end. Refurbished accumulator glass bead blasted and painted in Eastwood Detail Gray.
I did unfortunately have one of the fuel line securing lugs shear off, so I'll need to sort that to get it properly secured (any suggestions for the best option here please?).
And I have used DEI Floor Tunnel Heat Shielding for the underside where the exhaust runs. If I'm honest, not the easiest stuff to get right as it didn't cut too well, but it seems to stick very well with the adhesive backing and forms the shape quite well.
So essentially the rear underside is complete except for fitting the wheels, which I will leave til the end. Next is the front….steering rack, brake linkage, front suspension etc etc. Will be nice to have a rolling shell again. I just checked the date of the first photo when I stripped the shell…..1st Feb 2014 !!!!
you don't want to hear it but just make a new lug
make the smallest hole in it for a single spot weld and touch it up, i really can't think of anything else as it would just look a bodge
Makes my efforts look really poor.
I've been trying to get mine done for the best part of 20 years so don't fret over a couple of years!!
