Pistolpete's Mars Red Mk1 GTi restoration
Restoration thread for my 1983 Y-reg Mars Red GTi, non-sunroof model
vdubber2 said
Love the exhaust! How does it sound? I'm considering yours or a miltek and can't decide?
I'll try and post up a quick video to give you an idea, but to me it sounds fantastic. Quite subtle, but a nice rasp if you rev it. I've got a very slight rattle against one of the heat shields to sort (always tricky with a 2.5" system with clearance over rear axle as she's lowered quite a bit), but the fit is spot on.
yes, had my mk1 tested on 27 April - all good straight through. No great surprise seeing as I managed a paltry 200 miles in a yearnicci21paul said
some testing stations are still open
Great progress! Looking lovely
Will echo the same on the exhaust, it looks 'right' and sounds great too, sounds good when pressing on!
One thing I would say is definitely get the centre silencer, as above .. not the straight pipe, very loud! I've had to order the silencer.
I was planning on doing some back to back sound clips of silenced and un silenced, there doesn't seem to be much around for powersprint for reference
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
Agree with you on the Milltek; I have one on the Mk2 16v (Manifold included) and there is a lovely deep burble from them but as you rev there is a real howl/snarl from them higher up the rev range. Would love to hear it on the Mk1.
Took a couple of short vids today to give you an idea how the Powersprint exhaust sounds. It's a bit lumpy as car needs properly set up and has a Schrick cam, also has stage 2 head, 4-2-1 manifold and centre silencer.vdubber2 said
00107 - YouTube
00108 - YouTube
Have owned :-
Mk1, Mk2, Mk3, Mk4
Bugs, Buses, Type 3
Porsche 911T '71
Mk1, Mk2, Mk3, Mk4
Bugs, Buses, Type 3
Porsche 911T '71
Blanked off dizzy vacuum, set timing using induction timing light, it's bang on 6deg BTDC.
CO set to 2% and idle tweaked back down to 1000rpm.
When I drive car, it goes fine when accelerating, but it is a bit stuttering from low revs pick-up. Im wondering if the fuelling needs to be richer to cope with the ported/polished head, 276 cam, Audi WUR & throttle body, port matched inlet manifold, 4 branch manifold & stainless 60mm exhaust + K&N filter element with drilled air box.
Obviously I'll be taking it to a rolling road for a proper tune once I can get it MOT'd but this is just to get it as best as I can for now.
Pistol said
As you could tell from the vids posted above, car needed set up correctly. So I've gone back to start from scratch after borrowing a Blue Point CO gas tester.
I have the exact same problem, mines booked into my mechanics on wednesday, been tinkering with it for a few weeks but not getting anywhere I'll let you know what solved my problem when it's fixed
One of those is vehicles with MOT's that have expired more than 12 months previously (and weren't eligible for automatic TEC's as a result), as yours has.
Another recent change, though I think it's yet to pass into law, is bringing Northern Ireland into line with the rest of the UK and finally allowing vehicles over 40 years old to be MOT exempt… so maybe one, other or both changes will mean you can get out in the MK1 soon?
https://www.nidirect.gov.uk/articles/coronavirus-covid-19-and-motoring
https://www.aovc.co.uk/articles/press-release-from-department-of-infrastructure-re-exemption-from-mot-for-historic-vehicles
Before
After
I've never really had a chance to get back to it with all this going on, but it has never been running quite right since I first fired it up. Bought a cheap fuel pressure test kit off eBay and thought I had things set up ok. Borrowed a mates Snap-on CO tester to set the mixture and idle. It was still a pig when it was running from cold, coughing/spluttering and sounded like it was misfiring. Bit the bullet and ordered a proper K-Jet testing kit, really good quality kit
https://www.ebay.co.uk/itm/Gauge-For-K-Jetronic-Ka-Jetronic-Pressure-Tester-Fuel-Distributor/183950579736?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Rigged it up this morning and confirmed what I suspected, cold control pressure was way out. System pressure is perfect at 5.2bar, cold control was over 2 bar. I've already drilled out the 16v WUR to adjust the pressure, so wound this back to 1 bar as per the graph and you could hear the engine sounding sweeter already. Quick tweak of the mixture and idle and all good. Re-connected WUR electrical connector and the pressure steadily rose to 3.5bar as it should. Left for an hour and residual pressure still at 2.6bar so everything is looking great. It's obviously still a wee bit lumpy but that'll be the Schrick 276 cam, but it revs so cleanly now.
Now I just need to finish the interior. Gave the rear bench a proper clean:-
And that's her in the newly refurbished garage ready for winter. Engine bay is finally complete, just got to touch up the paint a bit on the metering head and give it all a damn good clean from the dust. Then get the paintwork detailed.
Is it all MOT'd (or the equiv) then?
You before and after garage pictures are like a 'spot the difference'!
J
Took my time, was very careful, got new LCD installed.
Put it all back together, plugged in……dead! Played about with it, got random segments illuminating but nothing better.
Sent the whole clocks off to Crazyquiffs hoping Rich could sort them, and he managed to get the clock working ok, but as soon as you try the MFA functions, the whole thing freezes and won't go back to even the clock function. Got clock back again by playing with fuse in/out multiple times. So I'll live without it for a while and continue the hunt for a spare MFA LCD circuit board.
So, out of the garage for a wash, clay bar, wash and dried.
Then back into garage and masked up
I won't bore everyone with the full detail but I gave her 5 stages of machine polishing starting with Menzerna FG400, followed by Menzerna Super Finish Plus, then Poorboys Black Hole Glaze, and 2 coats of Chemical Guys Jetseal 109 before a final application of Collinite 915 wax. I've still to fully finish everything such as bumpers/trim, glass etc, but I'm delighted with the finish now.
she looks sweet
could you link the instructions you spoke off please? I’m just too lazy to look 😚
could maybe help with the clocks if you want to pm me?
and I will take the opportunity to wish a Happy Xmas to anyone that reads this 😁
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
tubbett said
Hi Pete,
she looks sweet
Cheers tubbett.
This is the link I used for the clocks, there is also a good how-to on here by Satans Creation which I used.
4130 Products - Changing the color of the gauge cluster lights.
And yes, I should have said, Merry Christmas and a Happy New Year to all the Forum Users, many people have been such a great help over the years. Here's hoping for a few shows in 2021 so I can put a few faces to names/usernames !!
