Pistolpete's Mars Red Mk1 GTi restoration
Restoration thread for my 1983 Y-reg Mars Red GTi, non-sunroof model
Brake lines are all run in now. I had bought an Automec kit, but to be honest the front pipes weren't right for using the 22mm master cylinder, so I ended up buying a roll of conifer pipe and a brake flaring tool. In hindsight, I should have just gone this route to begin with, very satisfying job.
I've been mulling over exhausts for ages, but finally bit the bullet and ordered a Powersprint 60mm stainless system direct from Germany. Have to say, the quality is amazing. It does have a slightly upswept tailpipe which I'm not sure about yet, but will see when it's fitted.
Metering head and airbox refurbished with new stainless bolts, new gasket, all cleaned up and repainted in Eastwood Underhood black and Aluma Blast. New metering head o-ring seal etc. Managed to salvage the wee black VW/Audi sticker and stick it back on to keep it totally original.
chrisL said
Neat job on the brake lines. That is the master cylinder I'm after, where did you buy it and the reservoir please?
Master cylinder is a Meyle item from VW Heritage, the reservoirs are like hens teeth now to get new, but I already had one fitted previously so have just cleaned it up. Would prefer a new one though as the plastic has yellowed a bit.
Keep up the good work!
https://www.dmb.uk.com/prod/2041/volkswagen-metering-head-decal
Yomp said
metering head stickers here if it falls off!
Great find Yomp, might just get one anyway.
Yes I'm still going to the show regardless. It'll be great to see your car in the flesh (is it the red one?).
yes red 79 S1Pistol said
Last edit: by Pistol
As it be full sand or glass. Which ever you blasted it with. Don't care anyone says I've seen it so many times gets past all seals etc. There be a coat sand inside stuck on bearings and gears
Pull it to bits wash out and fit new seals
Audi 2.2 throttle body refurbished. Linkage removed and zinc plated, throttle body cleaned using Frost Ali Clean, then Eastwood Metal Prep and Ready, followed by Eastwood Etch Primer and finally a couple of coats of Eastwood Aluma Blast and Eastwood Crystal Clear Lacquer. I'm really pleased with the finish on these bits:-
Alternator stripped down, casings cleaned following same process as above, and also got the mandatory Mars Red strip painted on. Now ready for rebuild.
I've managed to get a new reservoir from werk34.de for around £55.
chrisL said
Excellent as usual.
Cheers Chris. I must have a look on werk34 for the reservoir.
Looking good, I will be keeping a eye on this
