Newbie in the market to buy - advice needed please
Mark 1 GTI convertible wanted - where to start
Thanks for the comments guys
Please can anyone confirm what the right decals are and how they should look on the black sportline?
Just Google golf mk1 sportline to see how they should look. Loads of pictures on line from different angles ect…
You need a left and right hence the 2 item numbers but at £75 for the originals you may want to go aftermarket as they are £22 up to you.
Are these correct? I have googled but struggling to get a close up on the decals - many cars seem to have them removed now days.
I know there was a seller on EBay who said those pictured like mine are wrong.
But they are mistaken.
These are fitted to car arches off the car. The extra actually wraps around the back of the arch.
I’ve got these on stock if you want correct ones.
Can anyone please advise what these would cost and indeed how many the DX has
Any recommendations appreciated too
Re:
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-SCIROCCO-STORM-FUEL-INJECTOR-VALVE-0437502023-049133551A/263932467458?epid=248676364&hash=item3d7399d902:g:93cAAOSwLqdbmOO5&_trkparms=gclientid%3DVRjQZCo0yeL6AAEaKqga_8fz0p9Ny0ZWFA3G9YMVXNPvnBAa_nLa72-24ZglyX4f&_trksid=p2489528.m4335.l8656Crowey26 said
Been advised the GTI requires fuel injectors
Re: Re:
Running too low.
I think it needs a good tune with timing light. I have this booked in.
Question: would a faulty injector have disrupted the running?
Secondly, and more importantly, what fuel should I use (I feel the need to keep apologising for my ignorance) but should I use Premium unleaded or normal unleaded? I am getting conflicting responses the more people I ask.
FYI the lastest with my little project is getting the drivers door finally sorted - dent and drop sorted plus the rear offside quarter panel dent and scratches sorted at a local coachworks.
Edging it toward the step up from where it was which will be a really smart looking and nice running Sportline to enjoy.
Rattle and wind noise from hood starting to bug me. Chortle I may be in touch…..
Adam
chortle said
Those arch guards are incorrect.
Had it at the coach works and now see that the previous decals are on there already but been painted over! URGH…
Getting the right Sportline decals put on anyways…
There’s a viton O ring that goes flat allowing air to pass through. Can cause erratic running etc.
Just make sure you have run though a good couple of fuel tanks of which ever type you want to use before getting the timing set up, it would be worth getting the CO checked also if you have replaced the fuel injectors, about 2% CO is what you are looking for.
What cleaning / maintenance products and techniques do you recommend for the hood?
Just about salvageable and the guys done a bang up job
