What feul pump to use for MK1 VR6 conversion?
rubjonny said
forgot to ask, what fuel tank do you have?
wiring sounds complicated i know sorry E/14 isnt so bad as its the only large pin in the plug, you cant miss it. plug e is the black one in the middle (see fusebox sticky)
D/13 you need a small round pin again nick it from a spare loom or crimp on a fresh one. the pin numbers are stamped into the front of the plugs too to make it easier to find them
Hi jonny.
have a few pics here of the fusebox, hoping you could point me in the right direction and tell me what some of these are, feul pump related etc?
if you need better pics let me know!
Thanks!
fuel pump power goes to plug M, i can see its plugged in already. the red/white wire with red plug needs permanent live, it goes into socket Y or the big red jumper block between 30 and 30b. the other single wires leave off for now, the brown/white is probably the interior light though.
for more info:
http://www.clubgti.com/showthread.php?219775
O.k, correct me if im wrong but if I connect the 4 wires coming from the fusebox (feul pump/tank wires M) directly to the 4 wires coming from the MK1 fuel tank/pump……shouldn't this just work?
See pics…
VR6 feul pump/tank connecter removed….
4 wires coming from MK1….
VR loom connected with Mk1 wires…..
O yes…and just curious what is this little plug running of the same loom but seperately if you know what i mean?….
2nd plug not 100%, its nothign to do with runnign of car anyway. if it was a 5 door id be tempted to say its for rear door pins?
I've got a late cabrio gti that I've had a 24v vr6 from a 4motion put in it.
The problem I'm having is that it's bursting fuel lines and running a little off. I'm using the stock pump although it's a new one. Should I get a new pump that's running less than 4 bar or is there a pressure regulator I need?
Josh
Sent from my LYA-L09 using Tapatalk
