1.8T Conversion Guide
The engines are the same to my knowlage in that there both 1.8t's and big port and would guess the internals are the same..??
The only thing's i'v found to be changed to transverse so far are both manifolds and the turbo.(still not certain on the exhaust manifold tho).
Thanx Shaun
\/\/ The beast to be…!!! (loads of pics) \/\/
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=95838&highlight=
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
I have a 1.3 MK1 Golf with an 1.8T AGU conv under construction and was woundering whats the best fuel system to use, would it be best to use GTI fuel pump and MK3 ABF Fuel lines?
Right so kjet pump is fine, what lines can you use for it? Ive currently got some mk3 plastic lines, will these be alright?
AMR said
Ive got so much confliciting information argh. Can we set this straight once and for all?
i used akjet pump and plastic lines and there fine so far 1yr down the line
foxy
Do they just push on to the fuel rail as well? Use a jubilee clip or something else?
you'll see what i mean when you look at the ends of the plastic hoses
