Series 1 gli EG won't start with new injectors
(In Topic #208633)
Found this online, anyone relate to this and think its worth a go?
Why were the injectors blocked? Have you cleaned out the entire fuel system including the filters in the WUR? Valve timing?, ignition timing? Does it have points and condenser being an early one? If the engine was running OK where the mixture screw is now then something is different. Fiddling with the mixture screw might work or you might just be treating a symptom and not diagnosing the cause.
Yomp said
You probably need to keep all you have done to this engine in one thread so we can see what else has been done. Is this the one that was seized? Have you done a compression test on it? It could be all sorts of things.
Sorry you're right I should have listed everything carried out, I actually found the starter motor has burnt out & caused a massive amp drain so looks like that's the non start issue initially thought my battery was giving up, hopefully rebuilding the starter this week, I've removed accumulator & pump replaced lines between both and cleaned out the whole system & brimmed with premium unleaded plus a new fuel filter, I will update when I get a good starter motor on it, the injectors were visually rusted from the outside from sitting for so long so hopefully that's all, valve timing is spot on and it is points & condenser but has good spark & brand new plugs, it doesn't have the timing mark like my clipper on the distributor is it just line the rotor arm with the 3 pin plug?
Regards Volkswarren
Just got my starter back home now so need to give it a go when I get the time, wouldn't think it was the same one that came out of the car would ya! Going to check in the bellhousing that it's not too full of crud and clean all electrical connections and give it a go!volkswarren said
any luck?
UPDATE: Rebuilt starter back in and all good, now with it turning over properly I can see that it is getting WAY too much fuel literaly flooding the while engine… Can anyone guide me on how to adjust the mixture to a ballpark setting?? Is the guide I attached in my previous comment worth a try?volkswarren said
any luck?
