Noisy Steering Wheel
Good Afternoon,
Can anybody tell me what's going on with this and how to fix it? It sounds horrible to drive with this rubbing noise.
Recently changed the ignition barrel so I all my locks was on 1 key put the steering wheel back on and this is the noise it's making.
if you are talking about the Scraping that you can hear when turning, it is either a DRY upper Bearing,
a lower shaft bushing that has fallen allowing the shaft to crape at the bottom, and or the finger wiper of the Shaft to the back side of the wheel needs some Dielectric Grease.
If you can pull on your wheel and it comes out about 1 inch towards you then you have knocked out your lower bearing… You simply look at the shafts bottom end and if you see a White or Yellowed sleeve, Push it back up, and secure it in place with either a hose clamp, or a large wire tie. Happens usually when replacing all the springs clips and collars to the upper shaft.  To prevent this in the future, you can use my Patented Replacement Method… That is prior to replacing the wheel make sure the lower bearing is in position.
Tale a flat blade screw driver about 10 inches long, and a medium number 2 blade, and insert it in the U-joint of the lower shaft.
Using a 1 foot long piece of 2X4 as a Fulcrum point, keep your foot on the handle of the screw driver to keep the shaft in position.
If your upper bearing was cleaned then you may have to add a bit more grease to it.
If your Wiper Stalks finger presser to the back of the wheel was cleaned or the back side of the steering wheel was cleaned then you need to apply some Grease.
Sorry for the late reply mate, just took my steering wheel off now and it seems to coming from the horn contact as you can see in this photo.
Also this doesn't look the healthiest does it? Surely this isn't right?
3A8A1377-A676-41EB-9220-8A77FA006572.MOV
Problem solved dosey a**e over here didn’t put the ignition cradle back far enough haha, oh well all fixed now and no scratching noise thanks Brian
Well a new turn signal switch comes with a new horn wiper finger.
