Cabriolet roof locking catches help
I will need to replace this rear cable soon as well as frayed and looks to be snapped. I fear at lot of rust underneath that rear lip holding the hood on as well…
Once these PVC go porous they actually hold the water against the body and the top frame itself.
Slowly rusting away under the top.
The rear cable and the rear cable channel.
chortle said
I’d look at the hood closely.
Luckily its kept in a garage and avoid use during wet weather for the moment. Depending on the extent of rust on the rear lip can this normally be fixed with some welding? Also am I right in thinking you provide quotes for providing and installing new hoods/cables? On my list of things to refresh for the future…
We often have to weld new sections in.
Sometimes if we’re lucky it’s only surface.
But it needs dealing with before you put a new hood on.
We can fit you just a hood or complete renewal of the top section headliner upwards inc new rear window frame as these are mostly rotten.
Or if you want just a rear cable no problem.
chortle said
Depending on how bad the rot is.
Lovely all sounds good to me! Will PM you tomorrow to get more details. Cheers
Hi. I have sent a message on Facebook regarding quote for roof works. Many thanks
