Tappety top end
(In Topic #205575)
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
I'm a little surprised because normally they are like that from cold until the oil gets up there.
This is a question that often comes up about the big block engines.
Just read your signature, I think you might want to change that now a bit!
Just kidding.
Just kidding.
It took me 7 years to post a picture!!
So we all wait with baited breath for the next one!
Tappety top end
Tappety top end
Tappety top end
Tappety top end
Hydraulic tappets adjust them selves but do also wear out, you can clean them out but which can help or buy new ones.
I think it's about 1985 when VW changed over to hydraulic tappets?
My Scirocco with solid shims, notice all 5 caps in place you will be missing No 4 (left to right) if you hydraulic tappets.
Tappety top end
Bucks_recovery said
If that is your car in the picture and your car is newer than 1987 (when VW fitted the body kit) and the original engine in it I guess you will hydraulic tappets, does the noise comes and goes.
What oil did you use and what oil filter?
Tappety top end
Tappety top end
Lots of places sell the oil filters as they are fitted to a lot of cars/models.
Crosland Euro car part oil filter not very good???
5W30 a bit thin really???
I guess you made the mistake of following the link on the Euro car parts page on the oil choice?
Don't believe what the Euro car part website tells you as it wrong on a lot of parts and info.
Oil, this is the stuff VW uses.
AVS Car Parts
Genuine VW oil filter
AVS Car Parts
Euro Mann filter - click on the right hand side to change brand as it keeps going to Crosland in my link!
http://www.eurocarparts.com/oil-filter
GSF Mann oil filter.
http://www.gsfcarparts.com/120vg0090
Euro oil, I use this for the last 6 years and found it OK.
http://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/engineoils/10w40-engine-oil/?521776011&0&cc5_245
Same oil here but £5 cheaper!
http://www.carparts4less.co.uk/cp4l/p/accessories-engine-oil/engine-oils/engine-oil/10w40-engine-oil/?521776011&0&cc5_245
Tappety top end
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1990/p/car-parts/engine-parts1/engine-parts/sump-pans-and-sump-plug/?333771291&1&47c8751ced189bff5450784e05f1acd1b6276fd2&000567
Or from here?
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-parts/engine-parts/engine-parts1/sump-pans-and-sump-plug/?333771291&1&e0aec9b5e00b9123d2c401ac898f4c8c66477e05&000567
Hope it does help but Hydraulic tappets do wear out, you can take them apart and clean them which may also help, there is a few guides on youtube but when I cleaned mine last year I could not remove the ball and spring from the insides as mentioned in the videos as it's not possible on my tappets as they are sealed.
Mine do sometimes tap a little when cold but they go quite again after about a minute and if you rev to about 2000 rpm then drop back to idle to get the oil pressure up.
Life Member
Dj Ev said
Quick update. Had a local technician look at my engine and he says it's getting oil and everything seems OK. So the only thing he could put it down to is the bottom end might be too powerful for the top end. In other words the head could do with a full refurb to bring it inline with the rest of the car. So if this is correct should i use the original TSR head and fit twin 40's or bike carbs, go back to the 32/36 that was fitted to the TSR head or is there another option like adjusting shims?? 😎
Blimey, you remembered all that after you drove away from the garage - or did the mechanic type it for you??!!!
I'd stick with the original engine and overhaul that!!!
