Cigar lighter conections
(In Topic #223623)
I'm back again with yet another issue' this time relating to my cigar lighter, there is a cone for cable that looks original and 1 cable that connects to the small bulb that lights up the ashtray unfortunately that cable was wired to the incorrect yellow/grey cable now I need to find where all these cables should route to as the lighter isn't working thanks guys
My Cigarette lighter won't charge my Ipad, Iphone. | Volkswagen Owners Club Forum
Whilst that tells you how to fix a funky working lighter, I have since removed them and used a USB jack in it's place as well Cigar's and Cigarettes are bad for you and you shouldn't be smoking, as my kids were using them for USB Aux thingies… and constantly it wouldn't work for my lighter to ignite my Stoogies. I bought a windproof Butane..
I decided to have a look last night and couldn't work out why there was no connection to the - side of the bulb' I managed to strip it down and have a good look' I could see the lighter was actually the wrong one the brass connection was to far away from the brass connector that attached to the bulb so soldered a small shim making it a little longer' the lighter would also not stay in the holder so slightly bend the steel pins in so it held it firmly but not to much' the proof of the pudding is yet to be confirmed' there is a spade connection on the bulb should this not be connected to the blue / grey ??
