Clutch cable?
(In Topic #222856)
I ordered a cable and will fit this week, if it ever stops raining…
My point is this will be the second cable in perhaps six months, so i must have done something wrong?
The first had been sawing through the bulkhead and eventually went. i fitted the repair patch thing and a new cable.
The clutch was still very heavy but at least it was fixed. Or so i thought!
Any pointers or thoughts?
Thanks.
Is it standard engine bay or modded in anyway thats creating wrong angle of pull?
On the drive
Myvalver 89 GTi Grey mk2 16v
Ill have a post mortem on the cable and see if it was rubbing on something.
Didn't look like it though.
85 GTi cab is the car.
Clutch cable?
You will need to put a container underneath it to catch the drips.
Oil like this.
3-in-One Oil Drip Can 200ml - Screwfix
I could be your clutch is old as they can become hard to use with age and needs replacing, LUK or Sach are the makes to go for…
I did lube up the other one too but I will do the same again.
I guess it could be an iffy clutch.
I'll get the cable on and think about it.
Any tips on adjusting?
if after all that clutch is still heavy its time for a new one, get a genuine sachs kit they're top stuff
Its "Telco". Carry on or send it back and look for "Gemo"?
Haven't really looked where the break is but im pretty sure it has broken right at the pedal as i found this little sucker on the mat…
not sure on the quality of those cables I've never used, heres a gemo:
https://www.vwheritage.com/172721335h-clutch-cable-1470mm-for-right-hand-drive-k-jet-vw-spare
Went very well, almost too well!? Done in fifteen mins.
Admittedly everything was new from the last cable i fitted and i did learn a few lessons last time.
It had snapped right at the pedal.
Which i think is from me using a screwdriver to get it over the hook last time. Time will tell i suppose. Everything looked right up there.
Better than it rubbing somewhere or a sharp edge or whatever.
Anyway, seems all good!
The hardest bit I found was getting the rubber bung fitted into the strengthening plate in the bulk head, I smear a little grease on it and fit the cable then press the pedal and the tension pulls the rubber bung into place.
Clutch still too heavy though.
Plus point is the other half hates driving it so not all bad!
