Anyone running Et18 8x15 wheels?
(In Topic #221400)
Found some one wheels for my cabriolet but it’s been a while since i got involved in all this et/offset business lol
so im a bit unsure if 18 is doable with this width
any help or guidance appreciated
car is lowered already but will be going on coil overs for final appearance purposes, just need to get the right rims that will give me the least hassle
But in a nutshell, and imo of course, they won't work.
Then I like my Mk1's super low with tucked wheels… some like the wide stance arch gap look.
But the fronts will be close!
Im running 15x8 et25. Im lowered 60 rear 30 front on AP Racing shocks and springs.
The only arch interference I get is if I hit a compression dip on a fast bit of road and the rears will just brush the plastic arches but my rear mounts are very tired so this could probably be cured.
The fronts are fine but I think another 5mm they may not be.
If you ran a 185/45 (which I did on my 15x7's) you'll be fine but personally I dont like the look on the 8" rim
Ignore the scrubbed sidewall the tyres were part worn
Current rides:
Yeah I'm a bit dubious about the fronts and calliper clearance
Don't want to have to push them out further with a 5mm spacer
I'm in a dilemma 😂 go wide and reasonably low, or tucked and loooooow
I'm fine with both looks tbh, I'm thinking wide is my preference having had low cars they are a pain to drive anywhere 😂
This car had 8 and 9 j rims on when i got it, so it's had some arch work already, the casting on them wheels was so bad though i couldn't make out what the off set was on them though lol
May just run the gauntlet with 8's all round and see! Nothing that a spacer or grinder can't sort out is it
Current rides:
Re:
Hiya mate sorry to chip in are they Stuttgart wheels ? As im looking at some Stuttgart st1s 15inch et 25 8j for my cabby and uts on coilovers so dont want to buy them and not fit ,have you had any issues? Regards DeanWATERNAIR said
Erm . . . Possibly, the rears should be ok.
Sent from my SM-T585 using Tapatalk
But be wary of stuttgarts they have savage offset and casting on the back in my experience!
My cabby had 8 & 9j 16 st4's on when i got it, they didnt fit without spacers on the front or rears, rears hit the beam without them and the fronts hit the calipers
I think they were et20? Cannot be sure as the casting was so bad on them i couldnt read it!
Deano777 they wont work with coilovers, there clearance is too close in the inside of the rim.
I changed from coilovers to shocks so I could run the wheels.
See below photo
Current rides:
