Bulk of parts from garage clear out
Open to offers on all parts here, I'll try my best to describe the condition. Images will follow under this post.
Can try and sort postage for some items if preferred, located in Honiton, Devon.
- 02A CTM Gearbox (Close ratio 1st, 2nd 3rd) - £150
- Raceland front upper strut brace - £30
- Front lowering springs - £20
- New Falken 175/50/R15 tyre - £40
- Brand new unused Classic VW Stainless Steel brake lines- £40
- Fuel tank with internal lift pump. Pump is in good condition, the tank needs work externally - £50
- 8v GTI rocker cover - £15
- 8v carb rocker cover - £15
- 020 gearbox 3.6 Final drive - £30
- Earlier scirocco front hubs and 256mm discs (no calipers) - £80
- Werk 34 Metal bumper bracket (New) - £15
-  Black side trims, some are bent but some might look OK when fitted, 1 of the lower trims is brand new from VW heritage - £20
- Chrome powder coated bonnet stay, a few wobbles but brand new - £15
- New Topran mechanical fuel pump - £10
- 4x Standard BBS RM lips, need a refurb - £40
- BAM ko4 injectors and fuel rail, came off a running car but I've never tested them - £20
- Original passenger side tail light (Frankani). Small crack in lense but could be a good spare - £10
- 1.8 Cast Iron exhaust manifold - £20
- Mk1 Caddy Rear bumpers - £30
- Pair of Headlights - £25
- Single LHD brand new headlight - £10
- Cabby wing mirrors, small crack on one - £5
- Single Pirelli P slot - £15
Last edit: by louiesmall
Can you elaborate on the cast iron manifold please.  Is it a bowl type or studs? Also pic if possible.
1992 Sportline Cabriolet in Red
Interested in bam k04 injectors/fuel rail, would need them posting.
I'll give you guys a PM with pics and more info,
How much for the lift pump and sender unit from the tank, thanks
If Pirelli p alloy is 7mm gap ( single A code ) please let me know cost inc postage ( uk) . Thanks
Can I have pictures of the mirrors please? How much is postage?
Thanx Shane
Hi do u have normal fuel injector pipes?,
Hi is the waistline trim still available?
Cheers Gaz
