RADIATOR CARDS/BAFFLES
Radiator cards
Hi
Trying to source radiator cards for 1991 Clipper. Any suggestions please?
Or any suggestions for DIY alternatives?
Try eBay item 273804222670, I’m not an expert but hope this helps
Re: RADIATOR CARDS/BAFFLES
dengeo45 said
Hi
Also interested in the diy solution!!
Verstuurd vanaf mijn SM-G935F met Tapatalk
I believe you asked Mars Red LA2A?
Mars Red it is !
I remember seeing a DIY solution once, but I'll be dammed if I can find it again!
Thanks for the tip Kingy - one down two to go !
den
I think the side cards are impossible to find, I did see some in the USA for $165, luckily I still have 90% of my old ones remaining (for tin top GTI with front oil cooler) so made some up out of millboard - they are difficult to cut but think they will look okay as mostly hidden out of sight.
Found this thread, seems quite useful:
Radiator Cards Radiator Cards | VW Vortex - Volkswagen Forum
Mars Red it is !
How different are clipper ones to the ones on a tin top?
Thanks Goldie.
Unfortunately apparently not a fit for my 1991 Clipper.
The top card and passengers side cards will fit but the drivers side card has a big cut out as that's where the air feed oil cooler sits in tin top cars, cabriolets have a water feed oil cooler so has a bigger card..
About 3/4 way in my project thread you can see the cards needed, these are original VW items which I bought from GCP (company no longer trading) about 10 years ago.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-daily-drive-1988-gti
