Replace cabby rear window seal
(In Topic #220552)
KP
Cabriolet Rear Window Replacement. | Volkswagen Owners Club Forum
Thanks Brian. I’ll try that. What type of rtv? Struggling to find the rtv you’ve used in your guide here in the UKBriano1234 said
None. I use silicone RTV on the staples, then with a new or old gasket that has been cleaned, and re-newed for the old Rubber that is Alcohol or wd-40 along the inner and outer scrapers and the inside grove cleaned as on the glass as well, Replace the gasket on the glass I refit it Directly after applying the silicone (not tons of it mind you) with the 2 wraps of nylon mason twine then push fit to the frame then pull the twine from the inside of the frame while I usually can get a helper to push the glass in (FLAT PALMS only.)
White for white ones.
Clear for all others.
Do you happen to have a pic of your rear window heater cables. I never took a photo of mine before I took it all out. Now I can’t work out where the cables go when trying to put it all back together. QBriano1234 said
Black for black tops.
Don't have pictures of the wires specifically, sorry.
