Fuel pressure regulator
(In Topic #220270)
Regional Host NE
the accumalator in a a different
description mate not sure
cheers paul
I did cut a broken one I had open once, there is a huge spring inside and it breaks open with quite a force!
thexvw said
Hi, they are not servicable unfortunatley, they only come apart if you cut them open (i.e. destroy it).
So would you say an old one would clean up and still work OK? I'm just dubious if they are rusty on the outside what they will be like inside and maybe cause problems in fueling
Regional Host NE
also another one still on a
car not sure how that one
looks will get a look over the
weekend if you are interested
cheers paul
Colley27 said
Sorry yeh accumulater I meant
nicci21paul said
hi i have one listed on ebay
cheers paul
So would this be fine after a clean up? How much are you wanting for these accumulators?
It may still work, were you having problems starting the engine after running?
Thats normally the sign that its not working along with a fuel leak from the small screw on the end.
TBH seeing the state thats in from the picture I wouldn't put it back unless there was no alternative.
I doubt very much you would unscrew the fuel fittings without them shearing off.
The K-jetronic system is high pressure, so you want the proper crimped braided hoses rather than rubber hoses and jubilee clips!
thexvw said
Hi,
It was a rolling shell and it was missing so need one, might pay to just get a new one rather than the chew on
thexvw said
Hi,
It was a rolling shell when I bought it and this was missing so might just buy new save any chew on
