1984 MK1 Golf GTi cabriolet
(In Topic #219969)
They are VW seats but looks like they have been re-covered already as they would not have that finish unless it was a special order.
If you find the paper sticker in the boot it should tell you have spec the car was when it left the factory.
Have a look here for sales brochures
https://vwgolfmk1.org.uk/index.php?page=galleries&type=misc&id=cabriolets
Not factory seating.
As an 84 model it wouldn’t of had the addiction of the body kit either.
chortle said
If you need the top section replacing the headliner hood etc give me a shout.
Do you have any new headliners?
Black or white?
I’m not an advocate of putting old stuff on as it’s usually not much better than what you’ve got anyway.
Plus it’ll end up needing to be changed sooner than later.
No point paying and doing the job twice.
Just send me a message about what you need.
chortle said
I only use new stuff.
Would be a white headliner, how much would one be? Would probably clean up ok but noticed a few wear mark on some of the edges so depending on price I may just replace it
Believe it or not I currently have the original Kamei X1 headlights and grill that came off that car for sale, see below including a pic with them still fitted.
I can tell you a lot about that car if you're interested. I had to replace the original DX engine and gearbox. With the replacement gearbox, is the second gear synchromesh still a bit weak? I actually still have another gearbox that I planned to fit so that I could overhaul that one.
https://www.gumtree.com/p/car-replacement-parts/mk1-vw-golf-original-kamei-x1-front-grill-four-headlight-conversion/1403633531
You purchased the car from my ex-wife. Unfortunately I had to give the car up as part of our divorce in 2016.
The engine and gearbox came from a Mk2 Golf GTI that was badly damaged and I purchased for spares.
I originally purchased the car in 2002 so owned it for 14 years.
When I drained the gearbox oil it was like draining lumpy mercury so that was a write off too.
The electrics were all shot to bits so the dashboard has been out and much of the original loom replaced.
On the plus side and probably most importantly the bodywork was superb both outside and underneath.
I have found some pics that I took when I first purchased the car……..
If there is anything I can do to help or you need to know anything about the car, please don't hesitate to ask.
I could never make up my mind whether to have the chrome or red grill, single or double headlights so actually had a combination of all of them that I kept swapping. Does look good with the red grill
