Mk1 golf gear change selector
(In Topic #219317)
Struggling for 1st gear
I'm not mechanically minded so I have to get the garage to do everything..
I'm going to get them to change the gear change selectors.
My question is what shall I get them to change while they are at it, if anything?
Thanks in advance
The gear box feels fine, it's just 1st gear that feels like it's not there 99% of the time.
Then 1 in a 100 it will just go in fine 🤷🏼♂️
Do you think the bits Iv posted above off eBay will help me Ian.
Luke
Recommended oil change 40,000 to 60,000 miles depending on how you drive etc…
2l is plenty, takes about 15 minutes to drain and refill the gearbox so not a difficult job to do with the right tool so should not cost much if done by the garage. https://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/car-tranmission-oils/manual-transmission-fluids/?522776022&0&cc5_868
stuff I use in both my cars..
Lukebow said
Thanks Ian
Luke
If you are trying to down shift from 2nd to 1st, while you are moving, that is a normal thing VW's that are aged love to have the car stopped before they get in to first.
Why don't you have a go yourself, it's easy, just do one piece at a time, clean it off well and perhaps a bit of silicon grease, you'll do a better job than the garage will.
Wheeler dealers demonstrated how to make it difficult, they took the whole contraption off the car in one go.
I'll get the garage to do it next week along with the oil change.
Thanks for your advice guys.
I'm not sure I know what you mean..
Could you possibly post a link please.
I would really appreciate it.
It's this rubber boot, on both mine and my brothers the bellows section came adrift. It would be worth checking it as the garage will have to remove it to fit two bushes on the selector rod - gear lever joint.
