Lambda probe
(In Topic #219094)
Lambda probe
Yes the 2 white wires are the heater wires and they can be cut and spliced together either wire can go to either white wire. The only one that is the sense is the black and you keep black to black.
The ground I always thought was a funny wire. It is only connected as a RF shield to the frame, so it isn't really needed.
When I changed my o2 or Lambda as y'all call it I could buy a generic one for 40 bucks or pay the 140 for oem.
I also moved my Bung to the down pipe as I had a cracked manifold and replaced it with a 4-2 g60.
I didn't like where the bung was that was on the down pipe so I had a new one installed on the right hand side. Makes changing it easier. So I had to install the sensor and in doing so I had to extend the wires a wee bit.
Lambda probe
gafo said
Thanks Brian I thought I was gonna have to spend more money . The lambda with the crappy thread only has about 10k miles I don’t know what happened to it . Can I use exhaust paste on threads when I’m fitting the new lambda or do I use something else?
I use never-seize only, I suspect that you can use a exhaust paste, but it all depends on do you want to get it back out? The Generic one is only like 27 dollars.
Lambda probe
I also have a Automatic,
But I placed both of mine on the right side of the car about half way up the right most down pipe, very easy to get to.
here is my mock up the welds got prettier when I had ot off the car.
Yep that is a old license plate being used as a Heat shield for the power steering rack.
Lambda probe
Lambda probe
Lambda probe
You can trim it down, but I think that you may be ok, I never have looked at one from the inside to see how far it extended in to the pipe.
But as long as it can have exposed holes I think you are going to be alright, as I said you can file it down a wee bit to give you more tip.
