1.6 caddy 1988. Fitting Twin Weber 40. Coolant manifold pipe
(In Topic #219007)
Not sure how to re connect coolant pipe with new manifold
The hole will need to be plugged. It's actually a warm water feed to warm the carb manifold during start up and running until the car is warm.
If I remember correctly the water flow isn't under a great deal of pressure so a bung may do it. A bolt may do it.
You'll love the sound and the extra torque you get is mad!
Stick with the mechanical pump and they'll be no need for a pressure regulator or anything else.
Don't worry about a choke either.
Good Luck
Ian
