Rattle rattle 😡
(In Topic #218295)
A good look round sees the downpipe heatshield loose and rattly.
Looking at the shield it is held on with two bolts onto the downpipe at the top and a rusted solid coach bolt which fitted between the two pipes??
After a couple of hours trying to access the coach bolt i managed to cut the nut of the bolt but because of its length it wouldn't push out the back as it kept hitting the steering rack.
So after another hour or so managed to get the two top bolts off as well then spent another half hour giggling it about to get off.
Rang VWH to order a new clamping bolt with some confusion as it seems this shield should be one piece and the clamping bolt is not a coach bolt type but a hex head nut and bolt. Also it seems as if the bolt does not fix through the middle of the pipes but to one side of it.
My question is that does the shield if i buy a new one piece one fit without taken the two c clamps off to release the downpipe?? and should the bolt fit between the pipes or not??
Sorry for the long explanation but have took some pics to show the abortion that was on.
Thanks again all.
1990 Golf GTI cabrio 1.8i. DX Engine
The wires need to go, use either new u-bolts or Stainless Steel zip ties….
Cheers.
That long Carriage bolt Probably is long enough just take it to a hardware store and get two just like it. Then smear it with Anti-seize so you can remove it easily in the future.
I also cut slits in my shield on one side to fit a SS hose clamp so I could position it solid to one of the pipes and clamp it in the middle…I also used washers to help pucker it in the middle to ensure of a good tight fit to the pipes….
Fit the bolt where ever it feels right, at the end of the day it's a Heat shield to stop rubber melting, fit it where and how it does the best job and bolt it up.
Thanks again all.👍
