Calibre Retro Stars
(In Topic #216197)
They're 15" Retro Stars and I really like them on the Caddy but the front don't quite clear the calipers which is a pain, so I'm looking at either a gentle caressing of the calipers with an angle grinder or some spacers. So the question is… does anyone else run with Retro Stars and how did you get them to fit on the front?
I don't really want massive spacers, but on the other hand I don't really want to be taking chunks out of the calipers…
When spaced out, the inside of the new wheel will be about the same as the old wheels, which will then push the out side of the new wheel further out (old tyres 185s, new 195s) so I may now need to extend the arches slightly… anyone know how much wider GTi plastic arches are?
Anyway, I've also managed to break a 17mm socket and my impact wrench, so I now need to replace them and buy some spacers, new wheel bolts and (probably) some arches, then get the wheels refurbished at some point in the future… so much for a 'cheap' wheel change (they do look good though)
Can you not change the calipers?
Can you grid some metal off the calipers?
May just be a case of changing carrier.
I haven't got any pictures at the moment (and need to sort out something other than photobucket) but the calipers look a bit like the ones half way down this thread
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=running-gear_2%2Fmy-brakes-rattle
If 4 spacers and 16 new wheel bolts are going to cost over £100, man maths means it may be time for an upgrade if I can find 'thinner' calipers…
*edit* would these fit? https://www.ebay.co.uk/itm/VW-Golf-GTI-MK1-1981-1984-Front-Calipers-Brake-discs-Pads-Front-Hoses-Kit/162604590694?fits=Model%3ACaddy&hash=item25dbfd2666:g:zwkAAOSw40pZd247 *edit* looks like I'd be stuck with the old carriers though..?
Last edit: by Blah blah
I think you can use an earlier type carrier with your existing calipers. Maybe rubjonny could advise.
So, does anyone have a pair? Or a set of calipers that'll bolt straight on without the loop?
Is the Loop that you are talking about the Caliper Bracket that the pads ride in and the carrier bolts to?
Grinding for clearance is one thing, but the front brakes do 60 percent of the stopping of the car. They are the number 2 safety feature of the car. The way you maintain it and drive it are the number one. Seat belts are a distant 3rd.
If you cheapen or fail the maintenance or drive carelessly, no amount of braking is going to stop you meeting new friends by accident.
I never modify the brakes at all….They are designed not to fail…. so if you are modifying them you need to err on the side of caution.
Be SAFER, not smarter….. My 2 cents….
Safer and cheaper to get new rims.
Give Crazyquiff (Richard masters) an email and ask him if he's got some.
Last edit: by Roach
Yes, I have the ones on the left so presumably I need the ones on the right (or some Vauxhall ones !), thanks for the heads up about 'crazy quiffs', I've sent him an email, have to see what turns up
I'll sort some photos out and update my RR thread because the wheels have changed the whole look of the Caddy.
Only problem I have now is that the inside wheel might touch the shocks on full lock (so I'll just have to not do full lock) - problem for the next MoT?
If the wheel is touching the steering rack arm or lower wishbone then check your steering rack is centralized (same amount of turns from straight ahead to full lock each way as that may solve your problem…
Looking good, I do like those wheels.
