Aux drive pulley and belt
(In Topic #216058)
I was wondering, if anyone knows what could be the item number for the crankshaft pulley for a V-belt drive for my '82 Golf 1.6D, engine code is CR.
Mine looks warped, as you can see from this video:
Also, what is the standard lenght belt for this system? Mine appears short and has little engagement on the water pump pulley… Also the alternator sits way lower, than expected, thus denting a metal part of the chassis, because of the short belt, (cannot explain it) (no photo yet, unfortunately)
Any input will be highly appreciated!
I don't see and issue of concern
As far as the alternator I would need to see how it is sitting statically in the engine compartment.
The engine rocks under accell. Which could be bad or worn motor mount or a tad adjustment of them.
There are various ways to mount the alternator, so I would have to ask if a/c is installed or not, and if it was a/c was the a/c deleted.
Pictures speak volumes.
Oh, which Alternator, Bosch (2 wires connected on lugs one large and one small blue)
or
Motorola (plug with 3 wires 2 red, one blue or black).
I will snap a couple of picture of the back of the Alt to identify its model, also will snap a pic of how it's sitting.
I am aware that the motor/gearbox mounts are shot.
The car had no a/c as far as I'm aware. It's the model with little to no extras
I think you need part No2?
https://volkswagen.7zap.com/en/rdw/golf/go/1982-7/1/105-6000/#2
VW part no. 068 105 255 H
Have you checked that the bolts holding it on are tight or perhaps the surface below the pully drive is dirty/rusty so it's not sitting flat on the surface?
Briano1234 Here are the promised photos:
Also, as you may be able to see on the last picture, the upper mount of the alternator sits a bit tilted, as it appears to be missing a washer of some sort, between the mount itself and the alternator. Please advise what can be done in this situation.
Thanks in advance!
You have a Motorola style of Alternator that was quite common on this side of the pond in the WESTY built Rabbits, and early Golfs built over here.
The issue that I see is at the pulley of the alternator, and or the bracket.
Seems to me that the Bushing that is on the bracket at the pulley side of the mount is on the backside of your bracket.
The Alternator isn't running true to the crank.
It looks to be sitting in the upper mount at an angle.
Over here on the non a/c equipped engine the alternator pulley sticks out further… Your pulley looks like it is for an a/c equipped.
But what about the dent, that has been done by the lower part of the alternator?
I have a haynes manual that gives me signs that the actual belt should be longer and the alternator sitting higher than it is right now. Has anyone swapped theirs recently? What lenght belt did you get?
(i forgot about the mount).
I think yours is mounted incorrectly…. as in isn't in the correct position, and needs to be rotated.
Here is my a/c Bosch alternator… my 81 motorola was mounted similar… Since you don't have York (a/c) wher the alternator mounted under things and the belt bully used shims for tightness.
I see this, so if yours is mounted like this with the bracket where I can't see it, then you may be ok, just not what i am used to seeing over here on a 1.5d or 1.6d
