Silly question but just wondered
(In Topic #215713)
Do I just replace the one or do the lot?
im not handy like most of you guys. Thanks-and do remember to polite,
best , Mikey
Send pic and someone nice will help.
On the drive
Myvalver 89 GTi Grey mk2 16v
first time ive looked after a classic and I don't–like all you guys–want it going downhill
Which would mean taking the door panel off and trying to locate the little büggers at the bottom of the door!
You will need them and again be careful during the refit.
You may be able to get new ones but check with Mark at Crazy Quiffs on that.
The job itself is very straightforward but just take your time and whatever you do don't bend them because you won't get any kinks out once they're there!
Any questions just ask. 😉👍🏼
Sent from my Smartphone ☃️
Will take it all on board
You can clear out the drain holes with a bit of wire or I use a cable tie as they won't damage the paint around the hole.
If you are getting water into the car the plastic membrane behind the door card could be damaged or worse case missing.
If you are replacing them go carefully levering them out as it's a bit of a faff replacing the metal clips in the doors which hold the scrapers in place.
If you are new to Mk1 Golf cabriolets the thing I keep an eye on is the fuel filler neck and regular clean the wheel arch as it's a great mud trap on top of the filler neck and that's why they rust and water gets into the fuel system.
If you need to know anything else etc please just ask, there's no such thing as a silly question.
cabriolet said
window rubber perishing on my cab .
best , Mikey
from the archive section a list of how-to's by briano.
http://volkswagenownersclub.com/vw/showthread.php/108497-Installing-your-new-outer-Scrapers-Kit
I beg to differ.
The silly question is the one you don't ask, and spend 3 days trying to determine what is wrong…. You ask the "silly" question in the forum, and you get the response back that resolves it in 30 minutes.
A lot of the silly Cabriolet ones are here….
View topic: My DIY list of things for a 90ish Cabriolet (digifant2) part 1 - The Mk1 Golf Owners Club
I needed a new speedo on mine and not being technical I nearly gave up on my cab.
Found one from eBay but since joining the club feel very much more confident that
A the parts exist to keep my car going
B the love and knowledge you guys have for your cars and are prepared to share are impressive.
