1.6 EG New Hall Sensor Suppliers?
(In Topic #212507)
Having hopefully traced the cutting out problem on my 81 GLi to the hall sensor, i am currently trying to source a new replacement.
I ordered last week this part from VW Heritage, which apart from being a pattern part, looked spot on:
https://www.vwheritage.com/035998065-hall-impulse-sender-mk1-golf-scirocco-t25-dj
The part that arrived looks like this, with the later square clip on type plug, so the wrong type.
DSC_9794 by Mathew Richardson, on Flickr
Having contacted VW Heritage, i have been told that the part pictured on the website has been superseded, and replaced with the part using the late type connector, which is what they have sent me.
My car uses the early type, as so:
DSC_9800 by Mathew Richardson, on Flickr
The obvious solution is to change the plug, however i wouldn't mind keeping the original type on a car thats fairly original mechanically, as i do intent to strip and detail the engine bay back to looking original at some point.
I can't be the first person to have had this problem, any suggestions/sources for a new part? I am loathed to source a second hand part as they are all 30+ years old now.
It then would be a better future investment if you ever had to replace it again.
I have had issues because like you I am a OEM type as well. But on issues of replacement parts and the like I have had to swap connectors.
I had that same part break on one of my cars, besides having to get it towed, I had to replace the Dizzy with a spare that I had. Fortunately for me the Diz was out of a 89 to go into my 92…. But I had to replace the Coil, as well as the ICM as they both got fried when the Connector broke and shorted out to frame.
then just keep an eye open for NOS or good used parts
