Anyone running thier 1.8T swap on Emerald K6...I have a few questions
(In Topic #212373)
1) After looking around the downpipe and along the exhaust it appears I dont have a lambda sensor plumbed in… I find this quite strange as im running a stand alone ECU…anyone seen this before?
2) The car appears to be running quite rich..on idle when you rev there are small black clouds and the car smells of fuel….maybe because of the above!?!?
3)I can see the conversion utilises the original VAG loom which was adapted to fit the Emerald K6 ECU and kept the N75 valve (this is used to control boost I think?) although the car drives fine on WOT i don't think im getting much boost as at the moment it seems as quick a mk4 1.8T 150bhp…and that weight quite abit more!
I plan on calling up Total VAG tomorrow to see if I can get some of the above answered but I was just wondering if someone could fill me in with the above or share your experiences running this ECU on the 1.8T.
A massive thanks in advance!
Waj
Further more I noticed under boost under WOT im readying 1.54 PSI…lol
I will be double checking all the hoses tomorrow to start with.. I have heard N75 valves are prone to failing…anyway to test these or run a MBC in its place?
Give jhon at emerald a call he is a very helpful
I am now boosting to 9/10.2 PSI which is a huge improvement over the sub 2psi I was getting on the N75.
Am I right to assume my N75 valve is faulty?…ideally I'd prefer to run the N75
I have double checked the loom for the n75 and it all seems fine..I'm certain it's not a boost leak either as when using a manual boost controller I hit and hold around 10 psi.
Am I right in thinking the ecu control the boost via the n75?
Last edit: by waj786
I have checked the plug to the n75 and can confirm both wires are showing 0 volts…after doing abit of reading apparently this should not be the case.
According to the Emerald FAQ section one of these wires should connect to Pin out 21 on the ecu for the earth feed and the other requires a 12v feed.
I have one yellow/black wire and another green/brown wire which is thinner on the n75 plug…does anyone know which one of this is meant to be the live feed?… I imagine the N75 is suppose to have a constant live and the Emerald ECU sends pulses through the other wire to control boost via the N75?…or I could be completely wrong!
Can anyone confirm which out of the yellow/black or Green/brown should be the live? (I'm certain it should be the thicker yellow/black one)
further more after having a look on the wiring harness, I can confirm I have nothing connected to pin 21..which adds to the confusion and begs the question how the fudge is the ECU meant to control the N75 without a feed from pin 21!??
