Fitting exterior window scrapers on a Cabriolet
(In Topic #210390)
I imagine this will be very easy, but thought it'd be worth checking first.
Thanks!
I just had to pry the old ones out of the latches, rolling the front windows down all the way helps you to see the clips.
Clean the old rails after you get the Scraper off.. Clean it well, and let it totally dry.
Then the 2-way sticky tape is good, but can get contaminated by fingers so I placed it on the rubber then stuck it on.
The rears were a pain in the posterior as the window doesn't roll all the way down.
Some have a metal spline that runs down the middle others don't.
But as Briano points out wind the windows down.
They are held in place by metal clips that are slotted into the door inner.
Just be careful you don't pull them out.
Iirc if they pop out you can use extra long thin nose pliers to pop em back,
You'll see how it all goes together once you take the old ones out.
If they are ill fitting afterwards check that the spline bit is actually in the clip slot.
I've done that before.
Have fun
But I have another one I am doing and I might take photos…..
