Cablechange set up
I know this has been done to death, I'm using Corrado 02a shifter and box which is mounted inside the car. Tomorrow I'm paying visit to breakers , I  want to mount new setup in the tunnel as I want use centre consul, what shifters should I get? What cables? Should I change to 02J tower ? Can I get shifter and tower set up the 02J type from one model of car instead of parts from a couple of different models? Thanks
Cablechange set up
So I got the shifter and tower from a 2000 tdi golf, I'll have a look at the weekend. the bottom plate that's under the gearbox two bolts hold it in position.
Cablechange set up
Sorry pressed wrong button, anyhoo the plate underneath the tower sits into it. Should it have a bearing? Mine doesn't have a bearing
Cablechange set up
these are the parts I got the small piece that bolts onto the underneath of the gearbox didn't come with a bearing
I dont think it should have a bearing.....the shifter tower just slides into it to keep it secure.
Cablechange set up
Cheers mate ..the gear stick is off mk 4 golf , looks like I have cut piece of floor , anybody know where I should cut
Cablechange set up
been at this today. Wasn't too difficult a bit of toing and froing under the car it's catching on the bracket on the steering rack. No room for angle grinder have an air grinder somewhere
If your gear knob is too low i have a little tip to make the gearshift more comfortable; On mine i lengthened the shift lever as it was too low, then i fitted a tt shift weight to shorten the throw. The tt shift weight replaces the standard mk4/seat etc shift weight on the top of the gearbox. I think it only cost £20 odd  from Audi.
Cablechange set up
Cheers mate , can I cut a piece of the old rado shifter and weld it on? It's threaded is it same thread as mk1 shifter? What's part no. For shift weight?thanks
Cablechange set up
Best gear oil, just checking what's best oil I might as well change it while I m at it
Cablechange set up
Any idea what the part no. Is for the t.t weight?
Cablechange set up
These were the parts I bought to refurb my 02J tower
Mk 1 Helios Campaign, 2.0 16v G60
Build thread here
Cablechange set up
I think it's probably one of the £21-£22 items marked 'lever'
Build thread here
Sorry missed this. Not sure on the part number for the shifter weight; my cars in storage so can't check. If you go to Audi its the shifter off the 5 speed tt's. I think it was around £20-25.
Sorty I can't be more help.
Cablechange set up
Part no is 8NO 711 051 A
Build thread here
Cablechange set up
Thanks folks , my shifter is from a 2000 tdi mike. So that part no is good for that?
Cablechange set up
It fits onto the splined shaft which I think is common to all 02J towers-maybe someone else can confirm? I changed the cable ends/Bowden catches at the same time-basically everything on those receipts if you Google the part numbers. I bought the parts in Jan 2015, so hopefully the part numbers are still current.
Build thread here
Cablechange set up
Cool mike good stuff, I haven't driven the car yet just have change gear oil . But from inside it feels much tighter gearshift
Cablechange set up
Forgot to ask about the reverse switch on the tower I took it off it doesn't look like it would work with the 02a engine mounts, what is the best way around this?
Cablechange set up
I did a hydraulic clutch conversion, so I was able to cut the clutch cable bracket off the mount-is that where yours is fouling? I still had to trim the plastic off the plug but it's possible to get it to fit.
Reversing lights aren't an MoT requirement but it's obviously still preferable to keep things work king
Build thread here
