mk2 16v rear brakes onto a mk1 - Handbrake cables?
(In Topic #208531)
Couple of questions really. The stub axles appear to be straight bolt on to the mk1 beam. Will the system work? and if so, any suggestions as to which handbrake cables to use?
ta Ian
Handbrake cables from a Mk2 Scirocco 16v are meant to fit.
https://www.vwheritage.com/shop/533609721/handbrake-cable-scirocco-16v-with-rear-discs-10-85/
Mk2 golf rear beam.
mk2 golf rear beam - Google Search
http://forums.vwvortex.com/showthread.php?5302255-FS-G60-rear-axle-beam-with-koni-struts-and-neuspeed-springs
Mk1 golf rear beam.
https://www.google.co.uk/search?safe=strict&espv=2&biw=1280&bih=918&tbm=isch&sa=1&q=mk1+golf+rear+beam&oq=mk1+golf+rear+beam&gs_l=img.3..0i24k1.32660.32891.0.33272.2.2.0.0.0.0.132.240.0j2.2.0....0...1c.1.64.img..0.2.240...0i7i30k1.ueTvhyCfVHo#imgrc=_
The scirocco 16v cables fit perfectly if the setup you have is from a pre-88 mk2 with 36mm piston calipers (they will have 36 or 38 cast into them) if later type and you mount them the right way up you may find the cables are a little short as the cables go on the bottom of the late type rather than on top like the early type.
on my mk1 cab I found this with mk3 calipers, to sort it I cut down the guide tubes under the car so they end up flush with the section welded to the pan. Worked out to around 10mm or so, you'll see what I mean! an alternative is pre-88 mk2 cables supposedly fit fine though I've not tried myself
I'd recommend mk3 calipers rather than mk2, they have a better handbrake design. check what you have they may already be mk3 type, if theres a spring on the handbrake lever they'reMK2, if not they're mk3
